Best Oil
Old Sep 7, 2007 | 08:31 AM
64FI's Avatar
64FI
Default Best Oil
What is the best oil to use in my engine? I was told that AMSOIL was great !
Old Sep 7, 2007 | 08:42 AM
vincentjames501's Avatar
vincentjames501
This is a controversial subject. You'd be best just to use Mobil 1 synthetic as the owners manual suggests. IMO of course.
Old Sep 7, 2007 | 08:53 AM
steve8's Avatar
steve8
I see no reason to deviate from Mobil 1.
Old Sep 7, 2007 | 08:54 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I use mobil 1 in the vette but amsoil in my bikes
Old Sep 7, 2007 | 08:57 AM
VetteFTW's Avatar
VetteFTW
Mobil 1 isn't even full synthetic anymore, there are much better choices. I'm going with the German Castrol formula for my next change, (0w30) it is supposed to be one of the best.
Old Sep 7, 2007 | 08:59 AM
blackblack94's Avatar
blackblack94
Yup....Mobil 1 is no longer a full synthetic.....my vote is amsoil!
Old Sep 7, 2007 | 09:01 AM
jrose7004's Avatar
jrose7004
I use Mobil 1.
Old Sep 7, 2007 | 09:20 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I use Royal Purple and just use a good full synthetic oil and you will be fine in a stock Vette
Old Sep 7, 2007 | 09:32 AM
RoganR's Avatar
RoganR
Old Sep 7, 2007 | 09:34 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Sep 7, 2007 | 09:39 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I too use the Mobile 1 for my changes!
Sometimes it's just best to stay factory on the fluids!
Thanks,Matt
Old Sep 7, 2007 | 09:44 AM
Gideon's_Test's Avatar
Gideon's_Test
Another vote for German Castrol Syntec (0W30). I've got it in my vette right now. In these parts it's only available at Autozone...
Old Sep 7, 2007 | 11:06 AM
T VETTE's Avatar
T VETTE
Here we go again
I would never use an 0w-30 oil unless I was an Ice road trucker.
Old Sep 7, 2007 | 01:12 PM
2KFRC5's Avatar
2KFRC5
Link ?
Per Mobil 1, it is a full synthetic motor oil.
Old Sep 7, 2007 | 01:18 PM
2KFRC5's Avatar
2KFRC5
Where does the Owner's Manual suggest to use Mobil 1? Quote?
My OM just states to use an oil that meets GM 4718M specs. The oil fill cap on the engine just says Mobil 1 is the factory fill. Nothing more, nothing less.
Old Sep 7, 2007 | 01:31 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Those of you who are saying that Mobil 1 isn't a fully synthetic oil anymore, where do you get that idea? According to their web site, it still is.
http://www.mobil1.com/USA-English/Lu...bil1_5W-30.asp
Show me something that says it isn't anymore and I'll believe you. Otherwise, get your facts straight before posting.
Old Sep 7, 2007 | 01:41 PM
TorchRed00FRC's Avatar
TorchRed00FRC
From a 2000 owners manual
"You should look for this on the oil container, and
use only those oils that are identified as meeting GM
Standard 4718M and have the starburst symbol on the
front of the oil container.
Your vehicle’s engine is filled at the factory with a
Mobil 1 synthetic oil, which meets all requirements
for your vehicle.
Substitute Engine Oil: When adding oil to maintain
engine oil level, oil meeting GM Standard GM4718M
may not be available. You can add substitute oil
designated SAE 5W-30 with the starburst symbol at all
temperatures. If temperatures are above 0F (-18C),
you may substitute SAE 10W-30 with the starburst
symbol. Substitute oil not meeting GM Standard
GM4718M should not be used for an oil change."
The manual also has a picture of the oil fill cap with the Mobil 1 on it.
So you can go both directions in the thread. Use only Mobil 1 or use oil that meets GM 4718M
Anyone concerned with warranty, just document that the oil changes were done at proper intervals and the oil used met the standard. Perhaps you may be in a better position if you stay with the factory fill.
With that said - Wally World right now has Mobil 1 5-30 for $17.78 for 5 quarts. The oil meets GM4718M. And this is what I use.
To Best Oil
Old Sep 7, 2007 | 01:50 PM
Midwest Vette's Avatar
Midwest Vette
I am using Amsoil. IMO I don't think Mobil 1 is as good as it once was.
Old Sep 7, 2007 | 01:52 PM
thisMSGgood4me
Based on what?
Old Sep 7, 2007 | 02:00 PM
terry621's Avatar
terry621
From: Peterborough"I'd rather be topless than all couped up" Ontario
St. Jude Donor '07-'08-'09-'10
Default All Fluids
Royal purple in all fluids except Brakes DUH
I like it
