Yeah, mine always says something rediculous like 58 degrees when its like 94 degrees outside. I guess I'll get around to changing it one of these days, but I don't think it affects anything else on the car.
That's the default temp. when the sensor goes bad. Only around $10 at the dealer. It can affect your air conditioning function...........
......Only around $10 at the dealer. It can affect your air conditioning function...........
Suprised the local dealer had it for that much, a steal on a Corvette part Mine read lower and lower until the A/C compressor wouldn't kick on 10 dolars to fix an A/C problem is money well spent
Mine read 68 when it was disconnected, after installing the Vararam. No problem when I reconnected it. It is easy to replace one. I guess a 2 minute job.
