Depends on what maintenance has been done;
Here are some rough estimates based on what can and commonly does go wrong and what should be done as regular maintenance (parts only, no labor).
Spark Plugs $20-$60
Plug Wires $60
Brakes (rotors/pads); $400
Tires; A lot of $
Steering Column Lock bypass $50
Fluids; $100
ECBM rebuild; $200
Tire Pressure Sensors $80 each (4 total)
Oil Pressure Sensor; $30
May also want to consider clutch replacement...
I'm certain that others will want to chime in. I just bought my '99 FRC with 111K miles on it a couple weeks ago. The price was right, and some of those problems can occur at any mileage. If you're saving enough, and getting a newer model year, go for it...Don't let the mileage scare you. The 'vette still has a lot of miles left on it...
Michlien ZP's would be about $1000 for 4
And the TP Sensors on the 03 he is talking about are cheaper ($30 each maybe, not sure, but they shouldnt need to be replaced on an 03 yet, no? I have 50k on my 01 nad they are fine, maybe with 100+k they go fater?).
Just take that extra cash your saving, and build a nice N/A or blower motor, throw in a clutch and DTE brace with gears, and enjoy it! If the car still looks new, make the drive train the same
I paid 15k for my car, 00 with 125k on the odo. Plans were to buy the car, and start pulling together the money for a nice newer motor, and to mod the hell out of it and hopefully pull out with a nice street/show car. I dont want to ruin a low mileage car and feel bad when I take it to vette shows
Have fun bud I did all my maintenance for under 600 bucks, including tires (thanks ebay!) Just be patient with it, these cars go on for 200k+ anyhow or so I hear...
Ok, Interesting. Say I purchase that high milage '03 and put in heads,Cam, and a new 3.90 rear with a new clutch.
Have I replaced most of the big wear items from the engine and trans?
Will this get me another 100K miles?
you can expect to replace the water pump, thermostat, perhaps a harmonic balancer, hub bearings, tie rod ends, diff. seals, seat covers, rocking chair repair if it hasn't been done already. clutch if it's a manual, coolant tank, radiator, alternator, a/c compressor, normal mantainance stuff. rotors, head light motors,
my a4 trans went out @203,000, motor, diff. still fine
