[Z06] Need some shifting advice...
Old Sep 8, 2007 | 01:58 AM
04_Z06_CE's Avatar
04_Z06_CE
Default Need some shifting advice...
Seems like 75% of the time when Iam trying to shift hard into 2nd and also hard into third my car will lose some traction but its not really the traction loss when your still spinning but MOVING foward but for me a hard 2nd and 3rd gear shift will have me losin traction side to side and than continuing to go foward. On top of this I also have the wheelp hop/tappin from the rear..
Its like chirpin every gear but doin so going left to right rather than chirppin moving foward...
Hope that makes sense...
Think my shifts might be too slow??
Should I be diff with the cluth maybe speed shifting?
Thx
BTw my car has halltech Trap and also Lt's....with 3.90's...
Old Sep 8, 2007 | 02:29 AM
Z06Electron's Avatar
Z06Electron
Mine stays loose sideways into the beginning of third gear, or 80 mph, then takes off like a bat outta hell. Mostly due to my crappy supercars. I have never had one ounce of wheel hop in this car though.
It's natural for that sideways twist to occur because of the amount of power that is being applied to the ground.
Old Sep 8, 2007 | 02:43 AM
ctusser's Avatar
ctusser
Might want to check rear tire pressure. If one tire is a few lbs different from the other it'll have a pretty severe pull to the side under heavy acceleration.
Old Sep 8, 2007 | 07:50 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Even though I'm stock, I would love to feel this car's performance (just once) without wheelspin. Admittedly my supercars are do for a change, I just hope I make the right tire choice to give me the best dry grip. No problems shifting though.
Old Sep 8, 2007 | 08:25 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The supercars like to be warm to really perform well, if they are cold and you lean on the throttle hard you are likely to have some serious spin especially if they got some miles on them.
To answer the first question in this thread I wouldnt say you are shifting too slow if you are yielding the results you say (spinning hard in 2nd and 3rd). You may want to smooth your shift out a bit by feeding the clutch out and squeezing back into the throttle quickly when you make a shift instead slam clutch in/out stomp on gas. If your tires are original and approaching the end of thier life span it just may be time for new rubber as well. Good Luck and practice makes perfect.... or at least gets you close
Old Sep 8, 2007 | 08:56 AM
BonestockZ06's Avatar
BonestockZ06
I use to have the same problem until I stopped powershifting the 1-2 and 2-3 shift. Now I don't get wheel hop and my ET improved by 1.5-2.0 tenths in the quarter.
Old Sep 8, 2007 | 11:52 AM
CJR2's Avatar
CJR2
St. Jude Donor '08
Replacing my Supercars with 19 K on them made a huge difference with the way the car hooks up. I feel a lot more confident driving the car hard now.
Old Sep 8, 2007 | 07:28 PM
MVR 155's Avatar
MVR 155
Any tire (especially a performance tire) after its a couple years old starts to breakdown compound wise and will begin to lose its elasticity/softness and will lose some of its grip, even a tire that appears to have a ton of tread left will lose performance.
To Need some shifting advice...
