1 to 4 skip shift
Old Sep 8, 2007 | 05:33 PM
ontcanuck's Avatar
ontcanuck
Default 1 to 4 skip shift
just bought a 2001 with 6 speed it jumps from 1 to 4 in moderate acceleration
Old Sep 8, 2007 | 05:42 PM
BarryR's Avatar
BarryR
You want to put in the CAGS bypass adapter. Cheap, easy and fun!
Good luck
Old Sep 8, 2007 | 05:46 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Good luck
CAGS and CLB should be the first two mandatory things you install on a C5.
Old Sep 8, 2007 | 06:00 PM
Navyvette04's Avatar
Navyvette04
I had the CAGS bypass installed at the dealership in my 04 vert. The total cost parts & labor was $75. It is well worth the cost. The 1-4 shift is a pain in the butt.
If you are wondering; the CAGS acronym stands for. Computer Assisted Gearshift Selection.
Old Sep 8, 2007 | 06:01 PM
ontcanuck's Avatar
ontcanuck
what is a CAGS adapter and were can you buy it and how much
Old Sep 8, 2007 | 06:16 PM
ytwokc5's Avatar
ytwokc5
Almost all of the forum vendors sell them. CAGS = Computer Aided Gear Selection. They are ~$20 and take 5 minutes to install. Just back the car up on a set of ramps and crawl under and click the CAGS in.
Old Sep 8, 2007 | 06:42 PM
z06Bigbird's Avatar
z06Bigbird
Do a search here, also. Tons of info.
Old Sep 8, 2007 | 06:45 PM
ontcanuck's Avatar
ontcanuck
Old Sep 8, 2007 | 07:21 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Good luck
or stop driving like a wussey and drive the car like a man
Old Sep 8, 2007 | 07:26 PM
C5naples's Avatar
C5naples
Yes, you for sure have to get rid of the cags.
Old Sep 8, 2007 | 07:32 PM
Icewind Dale's Avatar
Icewind Dale
I never have to worry about it. Who shifts at such low rpm's anyway? Not me I can tell ya that.
Old Sep 8, 2007 | 07:33 PM
Bob CTS's Avatar
Bob CTS
Best $20 spent for me, got rid of that da** 1st to 4th. CLB was the next best thing but that is a piece of mind since it works silently under the steering column.
Old Sep 8, 2007 | 08:33 PM
WWK888's Avatar
WWK888
Another case of the dealer ripping off someone. $20 for the eliminator and 2 minutes to install.
Old Sep 8, 2007 | 08:39 PM
Tigershark3's Avatar
Tigershark3
Yep, those were my first two on my '99
Old Sep 8, 2007 | 08:45 PM
RedSoxFan's Avatar
RedSoxFan
When I first got my car this CAGS thing irritated the hell out of me but that only lasted about a week or two. Now I don't even know it's there. Just shift at a higher rpm and the problem is solved, or at a lower rpm depending on the situation.
Old Sep 8, 2007 | 11:12 PM
Jet-Jock's Avatar
Jet-Jock
Congrats!
You absolutely want to do two things.
a) CAGS (Ecklers, Mid America, etc)
b) CLB (column lock bypass - Corvettes of Houston comes to mind) if it hasn't been done yet.
Old Sep 8, 2007 | 11:51 PM
rws.1's Avatar
rws.1
CAGS and CLB both form Corvettes of houston (COH)
To 1 to 4 skip shift
Old Sep 8, 2007 | 11:57 PM
vetterlatethannever's Avatar
vetterlatethannever
Definately get that CAGS eliminator in there.
Old Sep 9, 2007 | 08:05 AM
steve8's Avatar
steve8
Get the cags. I know all the macho guys tell you to just drive it correctly and it won't be an issue, but there are several low speed, local, traffic situations, etc. where the eliminator comes in extremely handy.
Get it.
Old Sep 9, 2007 | 09:17 AM
Novat_99's Avatar
Novat_99
Here is a picture of the CAGS eliminator installed in my car...simple, easy install....unplug the connector from the transmission...attach the supplied connector cap....next, take the connector line that you just unplugged and snap on the CAGS eliminator & zip tie it...so it doesn't move around & keep it clear of the exhaust.
