[Z06] Fuel filter question
Old Sep 8, 2007 | 07:45 PM
u4ick's Avatar
u4ick
Default Fuel filter question
Where is it?
How do I get to it?
Old Sep 8, 2007 | 08:32 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by u4ick
Where is it?
How do I get to it?
Either on the left rear frame rail above the axle or inside the gas tank, depending on exactly when your car was built.
Old Sep 8, 2007 | 09:56 PM
utryd2's Avatar
utryd2
How about a 02 Z06?
z06Bigbird's Avatar
z06Bigbird
Might try technical section or shop manual.
Old Sep 8, 2007 | 09:59 PM
Higgs Boson's Avatar
Higgs Boson
Your filter is in your gas tank.
Old Sep 8, 2007 | 10:32 PM
ctusser's Avatar
ctusser
Originally Posted by utryd2
How about a 02 Z06?
My 02's was on the left rear frame rail.
Old Sep 8, 2007 | 10:44 PM
utryd2's Avatar
utryd2
Old Sep 9, 2007 | 10:59 AM
TEXHAWK0's Avatar
TEXHAWK0
I think they switched from the frame rail to inside the gas tank sometime in the middle of 2003.
Old Sep 9, 2007 | 01:43 PM
royski's Avatar
royski
Default filter
my 02 z06 is on the frame in front of drivers side rear wheel
Old Sep 9, 2007 | 02:47 PM
u4ick's Avatar
u4ick
I presume you mean here?
This is what I bought........
And here is where it should be on my car.....Right?
As TEXHAWKO pointed out, I am apparently one of the lucky ones....
So now what????
How do I get in to get the filter if it's in the tank?
Old Sep 9, 2007 | 03:08 PM
ctusser's Avatar
ctusser
Dude, I feel for ya. Why in the world would anybody design a service item like a filter to be in tank?
Old Sep 9, 2007 | 03:22 PM
u4ick's Avatar
u4ick
It takes 4 years of brain washing to remove ones common sense, once it has been purged you are given the title of Engineer..... .....
Turns out I may have to be in there anyway (the tank).
I have been hearing a high pitched sound comming from that area and believe it may be the pump.....
See more on this in this thread:
http://forums.corvetteforum.com/show....php?t=1804297
Old Sep 9, 2007 | 05:14 PM
TEXHAWK0's Avatar
TEXHAWK0
You are right...that is exactly where the filter SHOULD be. Unfortunately, that is not where it is.
You have to pull the left side fuel tank out to get to the filter.
Old Sep 9, 2007 | 05:54 PM
u4ick's Avatar
u4ick
What all is involved with that?
Is that where the pump is too?
And I take it that is a different filter............probably 3 times as much as it is some sort of dealer only special order........
Old Sep 9, 2007 | 10:20 PM
TEXHAWK0's Avatar
TEXHAWK0
I have not actually replaced the filter on my 04, but I think it is part of the fuel pump assembly. According to GM, they should last 100,000 miles!
To remove the tank, you have to remove the muffler, a drive line support, the crossover between the two tanks, and all the lines.
It is not really a routine maintenance item anymore.
Old Sep 11, 2007 | 10:02 AM
Melsy's Avatar
Melsy
The filter was moved to the in-tank type in mid 2003 when they changed the entire fuel system.
Old Sep 11, 2007 | 02:18 PM
vms4evr's Avatar
vms4evr
A fuel filter that has a service interval of 100K miles? Not that I haven't run one that long... Mine is an 02 and the filter is right where it should be and I have the part u4ick posted. Mine is getting swapped at 40K along with the plugs, whether GM says they are good for a 100K or not...
That said we just rebuilt the top end of the engine on my wife's Monte Carlo with a 3.4L. 148K on it. I replaced the original fuel filter and plugs during the overhaul. The car never actually ran bad. Well until the intake manifold pissed coolant all over the place.
To Fuel filter question
Old Sep 13, 2007 | 11:23 AM
81c3's Avatar
81c3
Thats not BS its true.
Old Sep 13, 2007 | 09:10 PM
u4ick's Avatar
u4ick
No it's that they put it there!!!
Old Sep 13, 2007 | 10:28 PM
z06Bigbird's Avatar
z06Bigbird
Where is my shop manual when I need it??
