GY RunFlat service question
Old Sep 10, 2007 | 08:29 AM
Tom73's Avatar
Tom73
Default GY RunFlat service question
Just a very dumb question, my '04 is still under factory warranty. Have a slow leak in the right rear, looses about 10 lbs a week. Do I take it to the Chevy dealer or to the Goodyear dealer? Owners manual says "...contact the nearest authorized GM or Goodyear EMT servicing facility for inspection and repair or replacement..."
tom...
Old Sep 10, 2007 | 08:36 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
You can take it to either place, but Goodyear will equipped to handle it for certain whearas, the Chevy dealer may not be. Considering where you are, Corvette Country in Austin can help you as well.
Old Sep 10, 2007 | 09:30 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Check the valve stem nut first........
Old Sep 10, 2007 | 09:40 AM
Oldvetter's Avatar
Oldvetter
Torque is only 62 IN-lbs (note INCH not FOOT), so be gentle (the valve is plastic).
Note to other, series I (1997-2000) need more torque since they use o-ring verses gasket. They use 106 in-lbs.
Old Sep 10, 2007 | 11:08 AM
Bugaboo's Avatar
Bugaboo
also make sure the valve cap is not screw too tightly allowing a miniscule air release.
To GY RunFlat service question
