Tps Education
Old Sep 10, 2007 | 01:30 PM
MURPHY55347's Avatar
MURPHY55347
Default Tps Education
I need some education on TPS. I have had my 04 white on white convertible for 5 weeks now and in checking the tire pressures they are at 37 or 38psi in all tires. The tires are BF Goodrich TA KDW. These are brand new and were put on the car by the dealer before I got it (done as part of their GM Certified program). I know the door sticker says 30psi but I assume that is for the runflats that originally came on the car. Should I decrease the air pressure and then do I need to recalibrate the sensors?
Old Sep 10, 2007 | 01:31 PM
jrose7004's Avatar
jrose7004
I'd run them at 30 lbs cold.
Old Sep 10, 2007 | 01:50 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
32 Lbs. cold
Old Sep 10, 2007 | 02:20 PM
Oldvetter's Avatar
Oldvetter
30 psi cold and no recalibration necessary, but you will have to drive your car a little way to get new pressures to register.
Old Sep 10, 2007 | 02:29 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Old Sep 10, 2007 | 02:42 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Old Sep 10, 2007 | 02:46 PM
MURPHY55347
Thanks Guys!
Old Sep 10, 2007 | 06:22 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Lower them to 30 psi cold. By cold, I mean when the tires have not been travelled on. Remember, p.s.i. is Pounds per square inch and has to do with the weight of the car and the size of the contact patch as it relates to the air pressure in the tire. If the new tires you put on are the same size as the factory runflats the door placard still applies. You will not need to do anything to reset your tire pressure sensors after you do this.
Tire pressure is not a set it and forget it item. You will need to check and readjust this as the outside air temperature changes. The tire pressure will increase with increases in temperature and decrease with decreases in temperature.
Running with tire pressure in the high 30's will likely result in a horrible ride and prematurely wear the center of the tires.
Old Sep 10, 2007 | 07:51 PM
Bugaboo's Avatar
Bugaboo
Absolutely dead on
To Tps Education
