Headlight Noise when Turned Off
Old Sep 11, 2007 | 03:28 PM
garymilgrom's Avatar
garymilgrom
Default Headlight Noise when Turned Off
Hi everyone. There is a noise that sounds like an air pump coming from the front of my car when I turn the headlights off. It lasts less than 10 seconds then goes away. Anything serious?
Thank you.
Old Sep 11, 2007 | 03:50 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Thank you.
You probably need a new battery.
Old Sep 11, 2007 | 03:59 PM
Kale's Avatar
Kale
is it like
clikclikclikclikclikclikclikclikclikclik BRRBPDT!?
I was told it's a bad gear in the headlight assembly.
Old Sep 11, 2007 | 04:04 PM
Ron in MO.'s Avatar
Ron in MO.
Hi
It is most likley the plastic gear in the headlight motor is stripped out. Happend to me Friday night.Search the forums there is a fix that cost nothing except some time, if you like to fix things your self. It took me about and hour start to finish.You can also get some brass gears to replace the plastic one. Hope this helps. Ron Herndon
Old Sep 11, 2007 | 04:15 PM
diyguy's Avatar
diyguy
Easy fix - takes about an hour.. Get to know the name "Rodney Dickman"
Old Sep 11, 2007 | 05:10 PM
02MillenniumVette's Avatar
02MillenniumVette
Sounds like its time to put some brass gears in.
To Headlight Noise when Turned Off
