Settle a bet for me..
Old Sep 12, 2007 | 12:11 AM
veni vidi vert's Avatar
veni vidi vert
Default Settle a bet for me..
If I put heads and cam in a 60K C5, have I done any work that's going to extend the life of my engine? (That would include gaskets and things that go with the change also)...
Old Sep 12, 2007 | 12:12 AM
utryd2's Avatar
utryd2
I dont think you will extend your motors life...If anything you might make it shorter due the fact you will drive it harder.....Just cause you replace the top end, it will not make the bottom end any better......
Old Sep 12, 2007 | 12:14 AM
vetterlatethannever's Avatar
vetterlatethannever
jon c's Avatar
jon c
Old Sep 12, 2007 | 12:19 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Gaskets....don't forget the Gaskets!!!
You will have new gaskets! And I agree with the other posts in that you will be "exploring" the new performance capabilities of your new top end.
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Sep 12, 2007 | 04:50 AM
dieseldave56's Avatar
dieseldave56
Default actually...................
Actually you have increased the pressure on the 'old' rings , since the new valves are sealing nice and tight. I would say just the opposite would be true , that the replacement parts may just reduce the engines (rings anyway) life.
Old Sep 12, 2007 | 07:00 AM
csexton's Avatar
csexton
Chuck
Old Sep 12, 2007 | 07:56 AM
rws.1's Avatar
rws.1
IT won't increase your life span but it will increase your quality of life....
Old Sep 12, 2007 | 08:25 AM
lil vette's Avatar
lil vette
Fresh motor consist of:
Crank bearing (plasti gauge)
cam bearings
valve job
rings (hone or resize)
pistons if resizing
waterpump
oil pump
maybe rods....have em checked
timing components
gaskets & seals
Old Sep 12, 2007 | 10:02 AM
jrpedraza's Avatar
jrpedraza
Old Sep 12, 2007 | 10:40 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
you will love the way it runs with the heads and cam and I wouldn't even think about how long it will last. It doesnt matter. You will smile more every time you step on the gas.
Old Sep 12, 2007 | 10:54 AM
WKMCD's Avatar
WKMCD
"Everyone wants to go to heaven but no one wants to die"...Same goes for performance. Unless you forge the bottom end just adding RWHP is goin to further stress internal parts. TNSTAAFL.
Old Sep 12, 2007 | 11:29 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Said so well.
Paul G.
Old Sep 12, 2007 | 02:52 PM
jangelo's Avatar
jangelo
To Settle a bet for me..
