From what I understand, the level of tint you get on your car affects the range of the radar detector. But by how much? Did any of you experience this with your radar after getting tint?
IMPORTANT NOTE: Windshield heaters such as Ford’s
InstaClear® block radar from passing through the glass (look
for a brown tint). So do solar barrier windshields of the type
used on GM Venture-Montana-Silhouette-Trans Sport
minivans and on some imported luxury sedans (look for a
reddish or copper tint). Same for mirrored sun screens.
Detector performance will be greatly reduced when V1 is
mounted behind such metallic films.
Not sure why a non-metallic film would block radar???
so as long as i dont use the metallic type tint i should be fine. Thanks.
-steve
If you want to make absolutely sure, park across the street from a grocery store and face the doors (radar detector should pick it up), and as you move the radar detector around inside the car you will find the mounting spots that are best/worst for reception.
Lol... Yeh, radio waves travel right through a tint. Unless like the above man said it's a metallic tint it will work the same distance.
It'll be fine. Keep in mind a radar unit will pick up your speed far before the radar detector gets in range of it. Detector will work pretty good for those "over the hill" pop up zaps though.
