fluid changes
Old Sep 12, 2007 | 05:41 PM
ontcanuck's Avatar
ontcanuck
Default fluid changes
just purchased a 01 convertible 6 speed with 5000 miles should I change the brake fluid and antifreeze. These fluids have never been changed
Old Sep 12, 2007 | 06:22 PM
AlisonC5's Avatar
AlisonC5
Sounds like a good idea too me!
Congrats on your find!!
Old Sep 12, 2007 | 06:58 PM
stormrider's Avatar
stormrider
YES!!!!!! At the very least change the radiator fluid. I didn't change the radiator fluid on my 02 because I thought it was good for 100K miles and I ended up having to spend $700 on a new radiator last Spring. Turns out the radiator fluid is only good for 5 years or 100k miles.
Old Sep 12, 2007 | 07:07 PM
Ron222's Avatar
Ron222
Originally Posted by stormrider
YES!!!!!! At the very least change the radiator fluid. I didn't change the radiator fluid on my 02 because I thought it was good for 100K miles and I ended up having to spend $700 on a new radiator last Spring. Turns out the radiator fluid is only good for 5 years.
Definitely do the antifreeze and make sure you use Dexcool. Mines an 04 and just did it...plan on doing it every three years...cheap insurance.
Old Sep 12, 2007 | 08:07 PM
csexton's Avatar
csexton
Yes, change them and congrats
Chuck
Old Sep 12, 2007 | 08:55 PM
T VETTE's Avatar
T VETTE
ALL fluids, you will know you car now from day one. Sounds like a great car
Old Sep 12, 2007 | 10:08 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
As stated, you have to consider time along with miles. You've timed out on the coolant for sure and brake fluid costs about $5. Other questions?
Old Sep 12, 2007 | 10:12 PM
nmbis2k's Avatar
nmbis2k
Unless you have proof of previous fluid changes....I would change all since the car is six years old.
Old Sep 12, 2007 | 10:37 PM
I would definitely change the antifreeze. You can look at the brake fluid and see how it looks, but I would probably go ahead and change it too. It doesn't cost much even at a dealer to have it done.
Old Sep 12, 2007 | 10:47 PM
vetterlatethannever's Avatar
vetterlatethannever
Change it, cheap insurance down the road.
Old Sep 13, 2007 | 06:11 AM
Lancer033's Avatar
Lancer033
DOT 3 brake fluid is good for 2 years max. DOT 4 is good for 1 year. You're long over due
To fluid changes
