HID drivers, step inside
Old Sep 13, 2007 | 10:27 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Default HID drivers, step inside
Installed the HID's over the weekend. WOW, what a difference they make. BUT, what I want to know is how come when you hit the headlight switch sometimes the headlights pop right up and sometimes you have to turn them back off and back on to get them to come up? Anyone have any ideas?
TIA
Tim D.
Old Sep 13, 2007 | 10:31 AM
newyiddy20's Avatar
newyiddy20
i was told by a electrician who i trust very very very much,is that the HIDS are a drain on the headlamp switch (fuse) and that mine would have to be replaced eventually ! i have had the HIDS for nearly 3 years,so its a wait and see, i geuss. good luck
Old Sep 13, 2007 | 10:53 AM
jdmvette's Avatar
jdmvette
Night Owl for life
mine dont do that.
Old Sep 13, 2007 | 11:10 AM
newyiddy20's Avatar
newyiddy20
could be the "quality" of the Hids and the install also
Old Sep 13, 2007 | 11:40 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Mine dont do it either
Old Sep 13, 2007 | 12:00 PM
redstreak98's Avatar
redstreak98
I was just wondering where you got your HID set up and how much it was..
Old Sep 13, 2007 | 12:10 PM
Spoon83's Avatar
Spoon83
I have the McCullough 3000K kit and mine did the same but also had flickering every once in a while. the solution is to get the wire harness that is directly linked to your battery and it keep constant power on the ballasts and less strain on ur headlight switch/fuse. also the new digital ballasts could help...
Old Sep 13, 2007 | 01:27 PM
newyiddy20's Avatar
newyiddy20
sounds like a plan
Old Sep 13, 2007 | 01:31 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
I got mine from forum vendor DJ Motorsport. About 10 months now and work perfect and I use them a lot.
To HID drivers, step inside
