How to put BSM back on ????
Old Sep 13, 2007 | 07:29 PM
MedChoice Tony's Avatar
MedChoice Tony
Default How to put BSM back on ????
Hi, I spent 1.5 hours taking off/cleaning the area from the BSM. Now, I want to put them back on.
Where can I buy adhesive tape to put them back on? Do I need to buy it from GM, or can I just go to an auto parts store?
Thanks,
TonyP.
Old Sep 13, 2007 | 07:31 PM
R Devil's Avatar
R Devil
3M double sided tape should work. Why are you putting them back on?
Old Sep 13, 2007 | 07:32 PM
RedRiderZR1's Avatar
RedRiderZR1
Yes. BSMs back on....
Old Sep 13, 2007 | 07:35 PM
UKXPAT's Avatar
UKXPAT
Good to hear you're putting them back on just make sure you align them properly
Old Sep 13, 2007 | 07:37 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Tony, get the RED 3M exterior double sided tape. And as UKXPAT said, be careful with alignment
Stephen
Old Sep 13, 2007 | 09:24 PM
11yellowgscpe's Avatar
11yellowgscpe
3M Part # 03609NA. You will have to trim alittle when you put it on the BSM. Make sure you get all the old tape off. Go to MidAmerica and under the BSM there are installation instructions. It will give you the alignment measurements.
Old Sep 13, 2007 | 09:53 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 13, 2007 | 09:55 PM
utryd2's Avatar
utryd2
Old Sep 13, 2007 | 09:57 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Glad to see you came back to your senses!
Old Sep 13, 2007 | 10:07 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Old Sep 13, 2007 | 10:13 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
i just don't understand why you wound even think of doing that. but to each his own.......
Old Sep 13, 2007 | 11:21 PM
VetteDawg's Avatar
VetteDawg
This is a first for me.
I've never heard of anyone putting the BSM's back on.
- I luv mine -
Good luck.
To How to put BSM back on ????
