K&N Filter
Old Sep 14, 2007 | 06:44 PM
jttVette02's Avatar
jttVette02
Default K&N Filter
Anyone who is using a K&N Filter - did you use the gasket that came with it? I dropped the filter in without adding the gasket and everything seems to fit fine and snug and no problems driving it. Bad?
Old Sep 14, 2007 | 07:57 PM
hotwheels57's Avatar
hotwheels57
The K&N filter is just slightly thinner on the perimeter edges than an oem filter. The rubber seal is to ensure complete sealing against contaminants. It also might help make sure the oem air filter assembly straps snap tightly in place. It's up to you whether you use it or not. The real test will be in a few thousand miles whether there is any dust/bugs in places it shouldn't be. I've got K&N (or S&B) gauze filters in everything we own and this is the only application that called for the rubber seal.
...now, someone is going to tell you not to use a K&N...
Old Sep 14, 2007 | 08:07 PM
Robertelarkin's Avatar
Robertelarkin
Default K & N
I have over 100,000 miles on the K&N in my C4, no problems.............I have about 4000 miles on the K&N in my C5, no problems. I do not drive in dusty area, but the main thing is to keep it clean. I do use the gaskets that come with them, event though they are a not perfectly sized, they work, just make sure there is are gaps or holes in the gasket........
To K&N Filter
