Clear Front/side lenses - Pics!
Old Oct 1, 2007 | 07:45 PM
jttVette02's Avatar
jttVette02
How did you do the install on these? I can't see where to get to them.
Old Oct 1, 2007 | 07:56 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Old Oct 1, 2007 | 08:36 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
there is an access panel in front of the tire at the bottom of the wheel well. once the panel is off there are two or three screws that hold the light in place.
Old Oct 1, 2007 | 08:44 PM
jttVette02's Avatar
jttVette02
ah chit ... really? damn ... I just spent an hour taking off the shroud around the headlight, that screw under the hood, and trying to fit my bigass arms down in there. I was able to remove the bulbs but I knew there was no way I'd be able to get those screws out from up there. Even if I did get the screws out I knew I wasn't getting them back in.
I tried moving down the brake duct, which was easy as pie ... but unfortunately I can only fit about 1/4 of my forearm through there. I knew that wasn't going to do it.
hmm... maybe I'll grab something to eat and try again later ... now that I started I want to get it done
Old Oct 1, 2007 | 08:52 PM
jttVette02's Avatar
jttVette02
Did you have to take the tire off to get in through there? Even if I take that panel off just inside the wheel well I don't think my arm is going to fit in there.
Old Oct 1, 2007 | 09:27 PM
vmaquera's Avatar
vmaquera
Originally Posted by WKMCD
In the ongoing effort to create a truly monochromatic look I got rid of the stock side markers this morning and replaced them with clear. I've got a set of clear rear side markers coming. I need to get the black inserts for the front and rear badges and then the only thing left not black, white or a little polished will be the tag.
How much Horsepower did you get from this mod?
I like the look by the way. I'm thinking of doing the same thing.
Old Oct 1, 2007 | 09:32 PM
Bill Vett's Avatar
Bill Vett
It's a great mod for a white car!!
Old Oct 1, 2007 | 09:37 PM
Zilla's Avatar
Zilla
left my tires on and had the front end jacked up. When working on the left side I turned my wheels to the right and to the left when working on the right side, so the access to light was easy.
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by vettelover84
Thats pretty sweet. I am trying to decide if I want to go the all white and chrome way or do the black out thing. The black outs are illegal in ILL so I may just do the clear lenses. Maybe keep it looking stock......
Oh Well
Looking good though. White Vettes are the best!!!
they also have clear with black so that might be a compromise.
bear in mind that they're WAY more expensive than the others.
http://cgi.ebay.com/ebaymotors/CORVE...spagenameZWDVW
Old Oct 1, 2007 | 09:39 PM
Zilla's Avatar
Zilla
these light look best on a black vette
Old Oct 1, 2007 | 10:02 PM
criley's Avatar
criley
That looks really nice. Good stuff.
cam
Old Oct 1, 2007 | 10:40 PM
jttVette02's Avatar
jttVette02
haha ... DUH, turn the wheels ... One of those brain fart moments. Thanks.
Old Oct 1, 2007 | 11:01 PM
  #33
Sportsdude's Avatar
Sportsdude
Looks nice. I'll get a set if I keep my C5
Old Oct 3, 2007 | 05:14 PM
  #34
jttVette02's Avatar
jttVette02
Is the panel you removed inside the wheel well to the front of the tire or is it on the underside of the car in front of the wheel? I tried removing the screws (4 i think) of a panel right in front of the wheel but that panel wasn't coming off .. unless there is something I missed, which is quite the possibility.
It looks like there might be a panel on the underside that can be removed but I would need to jack up the car.
Old Oct 3, 2007 | 05:17 PM
  #35
Zilla's Avatar
Zilla
I believe there is one or two screw on the underside of the car. you should be able to see the panel and follow the shape. I am in Chicago on the road working right now so I can't give you an exact anwser.
Old Oct 3, 2007 | 05:26 PM
  #36
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
If you look straight down THROUGH your headlight, the access panel will be under it. In front of the wheel. My car is not jacked up at the moment so I cannot get you a picture of it. Should be approximately 4 10mm screws.
Old Oct 3, 2007 | 05:34 PM
  #37
16Again's Avatar
16Again
Front clear lens
Rear, clear brake lights, ZILLA recommended clear 3rd brake light, and clear side markers.
To Clear Front/side lenses - Pics!
Old Oct 3, 2007 | 07:05 PM
  #38
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Anything under $200 doesn't count.
anything under $499 doesn't count
Old Oct 3, 2007 | 07:10 PM
  #39
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Very nice a great Christmas present for me
Old Oct 3, 2007 | 07:11 PM
  #40
WKMCD's Avatar
WKMCD
I've got long skinny arms and fingers.
I took the headlight cover off and went through the top. There is an 8mm screw on the rear of the lense assembly. It's undeneath so you won't see it. Take that out. Remove the spring on the top of the lense. Going through the bake vent in front - use a deepwell 10mm socket to remove the front 10mm bolt.
Reverse the process to install.
