clutch rating?
Old Sep 16, 2007 | 08:08 PM
jzemo's Avatar
jzemo
Default clutch rating?
What is the max hp/tq rating on a stock c5 clutch. I have a 2002 with 25k miles and this winter I'm having a new motor put in. The new forged motor is as follows:
Stock block and stock crank (both new)
Mahle Forged Pistons
Callies Compstar Rods
Calico Coated Clevite Bearings
ARP main studs
ARP head bolts
FAST 90 intake manifold
230/232 x 112 cam
AFR dual springs w/ Ti retainers
Manley hardened pushrods
Eventually a 150 shot of nitrous but I think that will have to wait until next year. The motor will be a 348ci and should put out around 450hp and about the same on torque. I was just curoius if I needed to upgrade the clutch now or could I wait until the nitrous install.
Old Sep 16, 2007 | 09:39 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I would say you are on the edge and while your are dropping in a new motor put in a Textralia 0Z Clutch
This makes sense do it right the first time and it is pay me now or pay me later
Old Sep 16, 2007 | 11:16 PM
vincentjames501's Avatar
vincentjames501
A new clutch will never hurt. It can only do good!
Old Sep 17, 2007 | 07:40 PM
jzemo's Avatar
jzemo
how does the textralia clutch compare to the spec clutches??
Old Sep 17, 2007 | 07:51 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I never have had a Spec and I have the Textralia Twin and I like the way it works and it seems to hold my 700+ rwhp with no issues and the single should be fine in your setup, I would call A&A or ECS and ask them about the single disk Textralia setup and go from there as they install many of these
Old Sep 17, 2007 | 08:38 PM
utryd2's Avatar
utryd2
I have the Ram Dual Disc set up in mine, not chatter at all and great engagement! Could not be more pleased with it and had it done with my H/C/I swap and gettting it ready for the procharger this winter
Old Sep 17, 2007 | 08:41 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I've gone through two different Spec clutches and now have the Textralia with their ultral-lightweight flywheel... ...although I've not track tested it yet, (but quite a few burn-outs & occasional very hard driving), I personally think the Aussie 'Textralia' is the better of the two....
To clutch rating?
