Window Valet weirdness
Old Sep 17, 2007 | 06:36 PM
NOLAVette's Avatar
NOLAVette
Default Window Valet weirdness
I used my Window Valet to raise the windows after getting out of the car to pick up a few things at the grocery store yesterday. Windows went up as they should, but I didn't watch them close completely. When I came back out, they were down. Has this ever happened to anyone else?
Old Sep 17, 2007 | 06:40 PM
02MillenniumVette's Avatar
02MillenniumVette
Yes its happened to me before also. If the window feels any resistance, then it will go back down. Its just a safety precaution. Whenever I use it I always make sure it goes all the way up before I leave the car.
Old Sep 17, 2007 | 06:46 PM
KCJeff's Avatar
KCJeff
Yup. Having that same problem right now with mine. I haven't been able to determine where the WV thinks the window is encountering resistance.
Old Sep 17, 2007 | 06:52 PM
Odd Dog's Avatar
Odd Dog
Default I had this problem when I got mine...
There is a setting that lets the WV "Learn" your window, so it knows when to stop. Read the instructions on learning that came with it.
I have not had a problem since it "learned" my windows.
Hope this helps.
Old Sep 17, 2007 | 07:00 PM
02MillenniumVette
Here are the instructions also in case you threw them away.
http://www.topdowntech.com/documents/WV-100.pdf
Old Sep 17, 2007 | 07:10 PM
dndrsn's Avatar
dndrsn
Mine was doing that, I reconfigured the window up strength to strong.
Old Sep 17, 2007 | 07:13 PM
NOLAVette's Avatar
NOLAVette
Thanks guys-I'll go through the calibration sequence again.
Old Sep 17, 2007 | 07:25 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
yep, recalibrate and you should be good, happened here a couple times too
Old Sep 17, 2007 | 07:39 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
I had the same problem and I recalibrated the windows and no more problem....
Old Sep 17, 2007 | 08:58 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Been there, retrained that with the valet!
Old Sep 17, 2007 | 09:31 PM
jttVette02's Avatar
jttVette02
No problems so far for me ... couldn't live without it now.
Old Sep 17, 2007 | 10:03 PM
vet85's Avatar
vet85
after reading your post i remembered mine was acting up so i went out and reprogramed mine .that was about 10 minutes ago and im back on the computer ...works great again ......now that i think about it i started having the problem after the battery was undone ....maybe that did it .anyway all is well again.....
Old Sep 17, 2007 | 11:12 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
^^ What they said
To Window Valet weirdness
