2000 Coupe passenger window intermittant problem
Old Sep 17, 2007 | 06:58 PM
minitech's Avatar
minitech
Default 2000 Coupe passenger window intermittant problem
My 2000 Coupe passenger window sometimes will not go up or it will not go down. Then at times it does. I can hear a faint clicking sound in the door when the switch is pressed but no movement. Fuses checked out ok. Any thoughts?
Old Sep 17, 2007 | 07:07 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
Default Stuck Window.
I know I did a search on this subject and found where the motor would be in a bind, I took the door panel off and gave it a tap with a hammer like the post I read said to do and it started working again with no problems for about 3 wks now.
Old Sep 18, 2007 | 08:05 AM
minitech's Avatar
minitech
Mine works again now. Would like to sort it out so I don't have a down window and need to leave it somewhere or if it rains...
I am going to have the skin off this weekend for speaker install and can check it out.
Any ideas of what to look for or a way to get it going when stopped short of unexpectedly taking the skin off as I try to go into work?
Old Sep 18, 2007 | 08:03 PM
04tripleblkcoupe
Default Window Sticking
I know I have a Lincoln Mark VIII and the window does the same thing in it, and I can usually bump the inside of the door panel and while holding the button and it usually goes back to normal.
I know I tried it on the vette and the bumping part didn't work, thats why I had to remove the door panel to get to the motor cause it would click when you pushed the buttons but nothing would happen, then tapped with a hammer and no problem since, Wish I had more info for ya but hope this helped....
Old Sep 18, 2007 | 08:22 PM
Bakersfield's Avatar
Bakersfield
If your window sticks, just hold the window control button down and slam the door closed. It may take several times, but it should un-stick the motor. This is a typical problem. Some have suggested to run the window down and up once a week or so.
To 2000 Coupe passenger window intermittant problem
