Rear end "wobble" fixed !!
Old Sep 17, 2007 | 08:00 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Default Rear end "wobble" fixed !!
Well,the local chevy dealer had no idea what was causing it ( had it there at least 3 times ) but I found a c-5 mechanic around Dayton that said what he thought it was and sure enough it was exactly what he said. Broken positration preload spring. It has been doing this since the first owner ,who is the general manager of the dealership owned it . He could feel it doing it also.Wish he would have pressed the issue and had it fixed under GM.He did not say anything about it when I bought the car . Here is the broken part.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Sep 17, 2007 | 08:06 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Great information and I'm glad you found the actual cause...
Super photo illustrations too....
Old Sep 17, 2007 | 08:15 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Just goes to prove one again how good (BAD) Chevy Dealers are when it comes to servicing our Vettes.
BuckIVette's Avatar
BuckIVette
Jim, how have you been? What were your "wobble" symptoms? I have noticed a "hop" when I accelerate hard around a curve. Assumed it was the runflats. Just curious.
Glad you found out what was going on.
Old Sep 17, 2007 | 08:45 PM
1FINE99's Avatar
1FINE99
Cruise-In V Veteran
Hi John, been fine .Mine was a shifting feeling back and forth when I first moved it . Then it started making a gringing noise when I turned corners. If you think you have a problem ,I can give you my mechanics name and phone number.You know he has to be good to work on 1fine99. He is the best around this area.
Old Sep 17, 2007 | 08:46 PM
csexton's Avatar
csexton
Good info. Thanks
Chuck
Old Sep 17, 2007 | 08:50 PM
Bob CTS's Avatar
Bob CTS
Thanks for the post.
Old Sep 17, 2007 | 08:51 PM
Thanks for posting the fix for your problem. Might help someone else out with similar issues.
To Rear end "wobble" fixed !!
