Unusual
Old Sep 17, 2007 | 10:05 PM
slowerlowerdel's Avatar
slowerlowerdel
Default Unusual
99 Coupe had been sitting for 15 minutes and started car. Clock had reset to 1:00. No codes and reset clock to correct time and everything was fine. Any thoughts?
Old Sep 17, 2007 | 10:44 PM
utryd2's Avatar
utryd2
Is your battery stock?
Old Sep 17, 2007 | 11:04 PM
slowerlowerdel
No, and it is new.
Old Sep 17, 2007 | 11:09 PM
WetteVette's Avatar
WetteVette
Re-set clock and try again.
The only time I had trouble with my clock is when the battery was nearing the end of its useful life. After replacement, no problems. With a new battery, no idea what could be causing the problem.
Old Sep 17, 2007 | 11:14 PM
TexasMadMan's Avatar
TexasMadMan
Same here. Only time I had clock issues was when I had battery issues.
Old Sep 18, 2007 | 01:01 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Exactly. Just because it's "new" doesn't necessarily mean it's good. Or for that matter if it's THAT new possibly the connection or the cable isn't quite right. I too experienced what you are, and although it started the engine, it never reached proper standing voltage (12.8v).
Old Sep 18, 2007 | 03:13 AM
PierEagle's Avatar
PierEagle
Also, when my battery was going out, if I started the car while the seat was adjusting the seat would reverse and go to the far back or exit postion.
To Unusual
