Buying a 98 Vette
Old Sep 18, 2007 | 01:31 PM
98T/A's Avatar
98T/A
Cruising
Default Buying a 98 Vette
Hi everybody. I think i am going to finally pull the trigger and buy a Vette since someone totaled my T/A I really dont want to spend a bunch of money since we are also trying to buy our first house.... so i fouund a 98 Vette for under $20k with under 40k miles. Is there anything i should know about these Vettes before i buy? Should i stay away from the earlier LS1's? I know that they changed some things in the later years. Is there going to be any problems in modding this car as compared to the later modles?
-Loftin
Old Sep 18, 2007 | 01:35 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
The 97-98s have the best fuel system on them for boosted applications and with those miles if the car is clean and well taken care of I would buy it
Old Sep 18, 2007 | 02:38 PM
utryd2's Avatar
utryd2
Sounds like a great buy there......Just do the normal checking when buying any used car.....maintence reciepts/history, carfax, kick the tires
Old Sep 18, 2007 | 03:59 PM
SinghZvette's Avatar
SinghZvette
And if it has Ride Control make sure the F45 shocks are not leaking, they have caused me a lot of grief on my 98-coupe
Old Sep 18, 2007 | 04:29 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
124k miles on mine and I have modded it a bit...
Sounds like a decent deal just based on the facts you've given.
Old Sep 18, 2007 | 04:50 PM
Oldvetter's Avatar
Oldvetter
107,000 miles on my 1998 with only 2 minor problems (oil pressure sensor and one headlight gear).
No 98's had HUD (you can install but need an HUD instrument cluster also) and only last half year had active handling as an option (all have traction control).
Even 1997 C5's were as reliable as any later year. They did an extensive and effective pre-production engineering development progam.
Hope you have many miles of smiles !
Old Sep 18, 2007 | 05:08 PM
2 GRUMPY's Avatar
2 GRUMPY
89,000 on my 98 Coupe. Changed out the oil pressure sending unit and a/c and spark plugs and wires other than that everything works fine.I'm adding new exhaust this month since the stock exhaust is TOO QUIET !!! If you have the factory spark plug wires I'd recommend changing them out at sometime because they are spring loaded and the spring pops the boot off the plug just enough and it does't make good contact with the spark plug tip.
Old Sep 18, 2007 | 05:16 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I wouldn't worry about modding it one bit see sig below!
Plus my ProCharger is going on in the next month!
No problems!
Thanks,Matt
Old Sep 18, 2007 | 05:51 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
You should be fine with it. Just make sure it is thoroughly checked out and check all the codes on it first
Old Sep 18, 2007 | 06:24 PM
Sounds like a good buy to me. Just look the car over carefully (check especially for rear differential seal leaks, rocking seats, and the battery area - acid leaks). Good luck.
Old Sep 18, 2007 | 06:40 PM
IMXCITD's Avatar
IMXCITD
Old Sep 18, 2007 | 06:58 PM
GrandSportRob's Avatar
GrandSportRob
Have a dealer run the VIN..See if it had the column lock and the fuel gauge issue fixed..These are two big ones that could cost you money later...Sounds like a nice find...
Old Sep 18, 2007 | 07:04 PM
LF97C5Vette's Avatar
LF97C5Vette
Yeah - Get a GM Service History report on it... see all the work done to it while it was under warranty...
Check Carfax too - although it may only be marginally helpfull
Ask the dealership if there is any way they can fwd a message from you to the previous owner - and if they will, ask the previous owner for any tips, or problems he had on the vette. He may or may not be willing to help ya...
Watch for leaks - check for any damp or water damaged carpet.
Pull the codes from the DIC - there are instructions for this on the forum - and understand what each code means...
Basically - just do like everyone says and get the car a thorough looking over... Read the stickies on this board for common problems, and look for those...
Good Luck!!
Dan
Old Sep 18, 2007 | 07:23 PM
R Devil's Avatar
R Devil
Buy it. Go crazy.
To Buying a 98 Vette
