Electric Water Pump Hook-Up-Question?
Old Sep 18, 2007 | 09:23 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Default Electric Water Pump Hook-Up-Question?
Which circuit are you grabbing the ignition source from? (Yes I'm also using a relay!)
Is there any specific one you've used or are using? (or Number of the circuit to look for and attatch to?)
Any and all help always appreciated - I will be putting on my Meziere this weekend!
Thanks,Matt
Old Sep 19, 2007 | 02:54 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Pull the switched power off of the fuel pump relay wire under the fuse panel. Its right about the center of the wires, and its a gray wire (slightly larger than the others) This wire is only hot while the fuel pump is priming.. It then shuts off when the system is pressurized.
99% of all the EWP guys pull it from this wire..
Then pull the constant power right off the terminal stud off the side of the panel itself..
Old Sep 19, 2007 | 03:05 AM
spiral04's Avatar
spiral04
Hey Matt,
Down at the bottom right of this link, there is a how to.
http://ls1howto.com/
Old Sep 19, 2007 | 06:54 AM
madmatt9471
Originally Posted by spiral04
Hey Matt,
Duhhhh! Of course! Man I totaly forgot about this write up!
Thanks,Matt
To Electric Water Pump Hook-Up-Question?
