[Z06] Speedometer change
Old Sep 20, 2007 | 04:42 AM
dkny_stylez's Avatar
dkny_stylez
Default Speedometer change
I was wondering how much 20" rims would throw off the speedometer from the stock 18"/17" setup. I'm curious because I just got a photo radar ticket, and I want to see if I can use this to my advantage..
Old Sep 20, 2007 | 08:10 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Well the rim size doesnt matter as much as overall outside tire diameter does, having a very low profile on a 20" rim could net you the same diameter as a higher profile tire on a 18" rim. I believe if you go to www.tirerack.com there is a feature you can use to plug in 2 different wheel/tire combo's and see the exact differece.
Good Luck
