Need help!!! Tire question!
Old Sep 20, 2007 | 03:23 PM
matt3310's Avatar
matt3310
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
2016 C7 of the Year Finalist
2015 C6 of the Year Finalist
Cruise-In X Veteran
St. Jude Donor '09 thru '19
Default Need help!!! Tire question!
My 03 Z needs new rear tires!!! I want to run Nitto 555's. I found some at the store, but they are 285/35/18. Mine on the Z are 295/35/18. Can I run the 285's? Will they look funny or look right?
Thanks!!!
Matt
Old Sep 20, 2007 | 06:13 PM
matt3310's Avatar
matt3310
Cruise-In X Veteran
ttt
Old Sep 20, 2007 | 06:16 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I doubt that it would look funny? By the way I have a new pair of the Supercars if you'd like.........$490 for both plus ship..........295/35/18
Old Sep 20, 2007 | 06:25 PM
Gideon's_Test's Avatar
Gideon's_Test
The 285/35R18 is 0.2" shorter than the stock tire (not to mention the width). The difference in height may throw off your traction control (ie get an error, or inoperative traction control), because of the speed difference between the front and rear wheels. I am not certain what is an acceptable speed difference between fornt/rear...
Old Sep 20, 2007 | 06:37 PM
jbauch357's Avatar
jbauch357
people screw up their size stagger from front to back wwwaaayyyy more than you are planning to do - and don't have any problems. so go for it!
Old Sep 20, 2007 | 06:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Yep.
BTW,
mrm1149: Nice offer!
Old Sep 21, 2007 | 09:56 AM
matt3310's Avatar
matt3310
Cruise-In X Veteran
mrm1149 thanks for the offer, but I really want to get away from the Supercar tires!
If you guys say this tire is ok, Im getting them! Any other info? Anyone have a pic of this size on there Z?
Old Sep 22, 2007 | 12:41 PM
matt3310's Avatar
matt3310
Cruise-In X Veteran
Ttt
Old Sep 22, 2007 | 02:45 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Matt:
Check out this site and see what you think:
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Input the wheel/tire size you have now (on the left).
Input the wheel/tire size you plan to go to (on the right).
At the bottom it will show you the size differences
In your case
The sidewall, and the width will be smaller than stock wheel.
The tire diameter is smaller (663mm vs 657mm)
When speedometer reads 60mph (96.6km/h) actual speed will be 59.5mph (95.8km/h): 0.8% slower.
Toque
To Need help!!! Tire question!
