Convertible Back Window Falling Out... ideas?
Old Sep 20, 2007 | 04:42 PM
El Capitan 2002's Avatar
El Capitan 2002
3rd Gear
Default Convertible Back Window Falling Out... ideas?
Hey guys,
I have a C5 (2002) convertible and the back window has come apart from the top. I've thought about getting some epoxy and fixing it that way, but was wondering if you guys had any ideas?
Thanks!
Old Sep 20, 2007 | 07:30 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Search is your friend:
http://forums.corvetteforum.com/show....php?t=1766844
Old Sep 20, 2007 | 07:32 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by El Capitan 2002
Hey guys,
Thanks!
Gluing it is about the only alternative other than a complete top replacement. I've heard some Guys say J-B Weld works good. Gorilla Glue may, also, do the trick.
Old Sep 20, 2007 | 07:33 PM
cletus's Avatar
cletus
Mine just fell out last week ('01 Black Vert) and after reviewing the above referenced write up I sent for the Rhino glue and will be trying the fix tomorrow. I'll let you know what happens...
Last edited by cletus; Sep 20, 2007 at 07:34 PM. Reason: Said "Gorilla" glue instead of Rhino.
Old Sep 20, 2007 | 07:54 PM
LMBZ4ME's Avatar
LMBZ4ME
Default Rhino Glue
I had the same issue. I just used the Rhino Glue method mentioned above and let me tell you that is some strong stuff. Fixed my rear window.
Old Sep 20, 2007 | 09:33 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I also read the thread a couple months back and ordered the Rhino Glue and in about 10 minutes had my top back to factory sealed. Best and only thing to use..and believe me, I use everything from marine sealant to chewing gum.
Old Sep 21, 2007 | 12:30 AM
El Capitan 2002
3rd Gear
Default Thanks!
Thanks for all the above! I appreciate it! I'll try it this weekend!
Old Sep 21, 2007 | 12:52 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by AC54ME
That was one of the greatest tips/writeups I have seen on this forum...congrats to that guy...it should have been made a C5 tech tip
"gem"
Full Name:
George Meng
City:
Lower Marlboro
State:
MD
Country:
US
Your Zip Code:
20736
Occupation:
Lawyer
Year & Model:
2001 Convertible
Color:
Red
Old Sep 21, 2007 | 01:15 PM
cletus's Avatar
cletus
Well, I used the Rhino glue and it worked real well, easy, too. Hope it lasts...
Some tips: My glass wasn't completely detached (only at the top and sides) but I detached the whole thing which was too easy. I used a couple pillows between the glass and the waterfall to push up the glass. The top was up, but not latched. This made it easy to align it perfectly.
I cleaned the contact areas with a paper towel barely moist with water because it appeared so damn clean already.
Make sure the lighting is good; it's hard to see the clear glue on the glass edge.
I did about 12 to 18 inches at a time and that worked nicely.
Apply a bead of glue to the center of the area that attaches, then press firmly for 30 seconds. If a little glue shows at the edge of top and glass LEAVE IT! I tried to wick it up with a paper towel and smeared it 1/8" onto the window about 3 inches long and it now appears permanent. I'll try to use a razor blade and carefully scrap it off after it sits for a day.
Also check your defroster connections; one of mine was barely attached.
Good luck.
BTW, I called my local Chevy dealer (I've had OK work done by them) and they said they couldn't re-glue and said it would be $2500-$3000 for a new top. So the drinks are on me...
Old Sep 21, 2007 | 03:17 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Dang! You're so far away!
Had mine fall out while it was being washed. Did the glue thing and has been holding now for 2 years. I am VERY careful now when I apply pressure washing or drying it.
Old May 14, 2021 | 09:00 AM
durmax's Avatar
durmax
3rd Gear
How much glue did it use. how did it come. a tube or a couple tubes.
Old May 14, 2021 | 05:50 PM
grinder11's Avatar
grinder11
I've never heard of anyone using JB Weld on the rear window. I have a 2000 Vert. I personally repaired the loose rear window with 3M Window Weld. It's held up now for over 20,000 miles/7 years. I've also heard of guys having success with Rhino Glue. I would think that JB Weld would be way too hard. The 3M product is black, and looks similar to weatherstrip adhesive. I think it stays somewhat pliable. There's currently another thread going on this very subject. OP-As one post stated, search is your friend....
Old May 14, 2021 | 07:35 PM
The Rhino Glue method has been posted about on the forum for quite a while and seems to really work well.
Old May 15, 2021 | 10:06 AM
JimHarris4's Avatar
JimHarris4
Default Another vote for Rhino Glue
Mine back window is still tight and dry going on a year after Rhino Glue. Got a multi pack from Amazon and used the brush applicator on the glass and pillows on the inside.
Old May 15, 2021 | 09:36 PM
GettnBetter's Avatar
GettnBetter
I did the Rhino glue method, used pillows and balloons to press the window from the inside while it cured. The Rhino glue is just a thin viscosity super glue. This method works for a while but lasted only a couple years. The edges are peeling up, looks horrible now but still doesn't leak. A new top is required to do it right. The OEM glue is a urethane
Old May 16, 2021 | 03:14 PM
old stingray's Avatar
old stingray
Old May 16, 2021 | 10:05 PM
JimHarris4's Avatar
JimHarris4
Default I’ll take a stop gap for now
Originally Posted by old stingray
If Rhino Glue holds for a year or more, I’ll take that stop gap measure for now instead of paying g $1500+ for a new top. Mine only has 30k miles so my top is in great shape otherwise
I also hear people have great success with a 3M product.
To Convertible Back Window Falling Out... ideas?
