[Z06] Gas Millage and Headers
Old Sep 23, 2007 | 04:58 PM
Zosixin's Avatar
Zosixin
Default Gas Millage and Headers
It seems my gas millage has gone down a little after I put LT headers and tune. I use to get about 29 mpg on the highway now about 24mpg. Is this normal? I never noticed it before, but just took a nice road trip and reset my fuel average before I left. Thanks Brian
Old Sep 24, 2007 | 01:57 AM
striper's Avatar
striper
Did you get your car retuned after the install? If not, maybe that's your problem. The computer could be over-compensating a lean condition and dumping in more fuel.
Old Sep 24, 2007 | 02:11 AM
utryd2's Avatar
utryd2
Get it dyno tuned and you will be fine....and your probably keeping the rpm's a bit higher than you used to just to hear that beautiful sound of the exhaust
Old Sep 24, 2007 | 06:07 AM
Zosixin's Avatar
Zosixin
It has been tuned.
Old Sep 24, 2007 | 06:22 AM
99redhtvette's Avatar
99redhtvette
when i put my exhaust on i thought my mileage went down too, it was just my foot...haha give that a try
rick
Old Sep 24, 2007 | 08:36 AM
Zosixin's Avatar
Zosixin
I dont think it was my foot because I was driving on the highway and in 6th gear and I only got about 25mpg.
Old Sep 24, 2007 | 05:33 PM
Z06Electron's Avatar
Z06Electron
Look at my mods in sig, I got 29.4 mpg on the way home from the tune. I had a passenger and drove all the way to vegas and back with cruise set on 90-95, did a couple "spirited" driving runs and had 45 minutes of stop and go traffic on each trip due to road construction and an SUV rollover. Averaged 25 mpg both ways.
It isn't the long tubes effecting gas mileage.
Old Sep 25, 2007 | 08:22 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I actually saw a slight increase in MPG after doing my headers/cat delete and tune ~1mpg increase
Old Sep 25, 2007 | 09:38 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Tuning after headers shouldn't effect cruise MPG. Tuning for bolt-ons is generall WOT tuning to dial in the AFR.
When you're cruising the car is in closed loop and using the MAF and O2 readings in an attempt to achieve stoich or 14.7:1 AFR.
At WOT you go into open loop and pre-set fueling tables come into play, which is why you need to get the car tuned after mods as the car can't account for the new air flow.
FWIW I'm seeing 27-29 mpg w/ CC set on the highway even w/ my G5-X2 cam. However, around town I'm averaging 16-17mpg vs. 19-20 before.
To Gas Millage and Headers
