Sway Bar ?
Old Sep 24, 2007 | 09:31 AM
JUS 1 MO's Avatar
JUS 1 MO
Default Sway Bar ?
Is there any difference between a Z06 rear sway bar and a standard one. My 2003 Coupe's suspension was changed to all Z06, except for the shocks, which are Bilstein. The spare sway bar, which is the original one, looks identical to the one on my car. Is there any difference? Are they different part numbers?
Thanks...
Old Sep 24, 2007 | 09:34 AM
Yes, the Z06 sway bar is thicker.
Old Sep 24, 2007 | 09:50 AM
bm bradley's Avatar
bm bradley
Thanks...
just changed my out to the z06 sway bar from stock. it was a good move for me. I can tell the difference.
Old Sep 24, 2007 | 10:00 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Thanks...
Are you saying that yours WAS changed out to Z06 but your old one looks the same size? First, if your not the original owner he may have changed it to z06 before. 2nd, whom ever replaced yours did it not knowing they were the same. 3rd, your guy replaced a stock one with a stock one. All you need to do is visually look at a Z06 bar and then back to the stock one and you can clearly see the size difference.
Old Sep 24, 2007 | 10:04 AM
OIF2XVET's Avatar
OIF2XVET
should be obviouse to the eye
Old Sep 24, 2007 | 10:31 AM
JUS 1 MO's Avatar
JUS 1 MO
Well, i guess i better look a little closer. Can anyone give me the thickness of the Z06 bar, in inches or thousands?
Thanks for the help....
Old Sep 24, 2007 | 10:54 AM
bm bradley's Avatar
bm bradley
whoops!!! wrong post
Old Sep 24, 2007 | 11:05 AM
Vega$Vette's Avatar
Vega$Vette
These are pics of the front and rear sway bars. ZO6 on the bottom (in each pic) and stock Coupe on the top.
You can easily see the difference.
Old Sep 24, 2007 | 07:20 PM
JUS 1 MO's Avatar
JUS 1 MO
The one on my car is .950 and the other one, not on the car is .913, what have i got? Is the one on the car a Z06 sway bar?
Old Sep 24, 2007 | 08:58 PM
Vega$Vette's Avatar
Vega$Vette
ZO6 sway bar is 23.9 mm (.941"). So you have the ZO6 bar. Your measuement is just a little off.
Old Sep 25, 2007 | 09:15 AM
JUS 1 MO's Avatar
JUS 1 MO
Vega$Vette, thank you for the measurements. I am going to have the sway bar powdercoated. Just wanted to be sure it was a Z06 bar before i had it done.
Thanks again to all replies....
To Sway Bar ?
