I have two questions. Number one, I'm just curious as to which tuners most dyno shops accustomed to using? Also, I just recently installed my Vararam and I keep throwing a P0172 and P0175 code. Which are running rich codes. Could not oiling my filter cause this? If not, would a tune be able to get rid of me running rich? Also it seems as though I have a slightly rougher idle. Should I do a Idle/PCM relearn?
HP tuners
The tuner will reflash your PCM with a new set of tables and get you better performance, likley better gas mileage and get rid of the code causing situation.
