Driver's side mirror loose
Old Sep 26, 2007 | 10:12 AM
Fratbragen's Avatar
Fratbragen
Default Driver's side mirror loose
Hello all,
New Corvette owner here (loving it by the way). Picked up an 03 coupe with 13,500 miles, perfect shape. Only problem, the driver's side mirror is loose.
Can anyone tell me how to pull apart the plastic on the door to get in there and tighten it up???? I started pulling at the top piece, but it didn't seem like it wanted to come off.
Any and all help is greatly appreciated!
Old Sep 26, 2007 | 11:38 AM
OUR97's Avatar
OUR97
Do a serach on this forum. You will find a lot of information about this problem.
Old Sep 26, 2007 | 12:38 PM
TEXHAWK0's Avatar
TEXHAWK0
If it is loose, you need to fix or replace it before it pops off and is left hanging by the wires.
There is not an easy fix. You have to remove the mirror, compress the spring and come up with a better method of retaining the spring than the press on clip. Several methods to fix the mirror have been posted.
When you say it is loose..Do you mean that the base is loose on the door, or the mirror is loose where it swivels on the base. If it is just loose at the door bolts, you will be lucky.
To get to the mirror, you need to remove the door panel, and any of the instructions for working on the window, the door handles, etc. with have that procedure documented.
Old Sep 26, 2007 | 12:44 PM
Fratbragen's Avatar
Fratbragen
Thanks TEX, I am lucky as you say and mirror fixture is loose where it meets the door. Huge help, many thanks.
Old Sep 26, 2007 | 01:06 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Here you go - a DIY instruction guide:
http://97vette.com/howto/mirror/index.html
Old Sep 26, 2007 | 01:31 PM
Fratbragen's Avatar
Fratbragen
Thanks all
Old Sep 26, 2007 | 03:01 PM
Green LT1's Avatar
Green LT1
As noted above, this is not an easy fix. Bth mirrors on my '97 were loose, and I tried to do a fix. Major pain in the neck. I ended up buying two new mirrors from a supporting vendor, and having them painted to match and installed. Not the cheapest fix, but probably the best...
Old Sep 28, 2007 | 10:42 AM
Fratbragen's Avatar
Fratbragen
Using the instructions, took apart the door and tightened down the nuts on the mirror, good as new.
I will say you think you're destroying the door panel when you're taking it off, but it's just the male plastic peices coming out of the female fixtures. Got it all back together, good to go.
Thanks all
To Driver's side mirror loose
