sterring coulumn lock
Old Sep 26, 2007 | 07:35 PM
Black76's Avatar
Black76
Default sterring coulumn lock
I have a 1999 c5 got in it today it started up fine but the sterring column will not unlock cant turn the wheels the read says sterring coloumn lock any one have any thoughts
Old Sep 26, 2007 | 08:18 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
You may want to try this. Turn the key to the off position and remove it from the ignition. Next, firmly tug the steering wheel back and forth several times, it may help to give you better leverage if you stand outside the car while doing this. Then get insde and turn the key to the "on position" without starting the engine and the column lock should release. This has worked for many people including myself on my '98 Vert.
Once you release the pin and unlock the steering column you can install a Column Lock Bypass.
Install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get from either of these vendors:
http://www.corvettesofhouston.com/pr...e9bf70207aef69
http://www.thunderracing.com/catalog...d=220&pcid=156
Here is a sticky thread from the C5 Tech section:
http://forums.corvetteforum.com/show....php?t=1015483
Old Sep 26, 2007 | 08:52 PM
SilverBullit02's Avatar
SilverBullit02
This column lock issue is really getting out of hand lately. There have been several posts regarding this in the past few weeks. Do a search and read them!!!. The first 2 issues of the recall removed the locking device in the column, but did not correct the fuel shut off feature!!!. Many of the after market kits don't address the fuel issue either. My neighbor just had the same problem . The car shut off when reaching 2 MPH. The 1st 2 portions of the recall had been taken of previously, His column didn't lock, but the fuel shut off. He also had a column lock bypass kit already installed from an aftermarket source. The kits do not completely eliminate the problem He got the pull key and wait....... and also "column lock" on the DIC. He had the car flatbedded to the local dealer for repairs. They told him $450.00 for repairs!!!. He is somewhat disabled and doesn't speak very well so I did the calling to the dealer for him. I explained to the service manager that PRODUCT SAFETY RECALL .GM-P06-028-04006C needs to done. This is an unpublicized safety recall. There is a phone # in this bullitin that can be called by the service dept and it explains that this is a SAFETY RECALL and will by covered by GM regardless of mileage, time, or # of owners. The dealer didn't believe me.I said just call the #!!!. They called me back about 1/2 hour later..They will fix my neighbor's vette @ NO CHARGE.per GM. This "C" version of the recall elimiates the fuel shut off issue. The first 2 portions of the recall MUST also be done prior to the "C" portion. I believe that this latest version also instructs the dealer to destroy the previous 1 and 2 recall paperwork. From now on, they are to do the entire procedure, remove the locking devices and install the new kit that eliminates the fuel problem. Many members will tell you they have had problems after the GM fix. That's because they only had the 1st 2 steps completed, Their columns didn't lock again, but their fuel shut off. Hope this helps.
Old Sep 26, 2007 | 09:27 PM
Black76's Avatar
Black76
I want to thank you for your reply i tried what you suggested and it worked like a champ the wheel is free once again
Old Sep 26, 2007 | 10:57 PM
88sk's Avatar
88sk
I just put 1 in mine ,didnt have any problems before but for $30 hopefully I wont, dont wanna go to the dealer cause I have a cutom tune (h/c,exhaust etc..,)which will erase it ,something to consider if your not stock,thunderracig is on ebay ,just put a bid in & leave it as they do 2nd. chance offers which some people dont know about
To sterring coulumn lock
