[Z06] Top Speed
Motortrend had a great article about published verse actual speeds in their October 2007 issue. Plus some really great pics of Danica Patrick.
http://www.motortrend.com/av/roadtes..._overview_one/
www.openroadracing.com
The down side is it will take you a minimum of 4 races to get a chance to run full out. And you have to have a car set up ie cage,fuel cell, fire supression system.
the upside these events are a kick in the a$$ and a great group of people that do it.
Jeffy'
Jeffy'
Jeffy'
and you actually answered the guy's question, too.
In theory maybe but in real life, no. I have heard many times that 6th gear can not physically handle it. You can have the power but from what I understand 6th gear is to small to handle the pressure of a top speed run. Unless somebody can prove otherwise? I'm all ears.
He has extensive video documentation of easily blasting near 200mph. Lingenfelter's 650hp car is rated for 226+ mph in a coupe! I don't understand why anyone doubts that speed. One thing for sure, you gotta have large kahunas to go do it! That open road racing looks AWESOME!!!
I doubt you drive much over 200 mph in a car without all that safety equipment. I wouldn't.
JB
http://www.corvettekillstories.com/p...ics/200mph.wmv
It looks like 6th gear holds up fine. In Joels setup, the gearing makes 6th gear wind out quick and top out at 200mph. I imagine that stock ratio gearing would wind up slower, but top out higher. It would likely take me 4 miles of road to even find out!
It might be worth going to Nevada to try it, and get kicked out.
Hey Jeffy, what's your setup (tranny/rear) for running 200+?
Z06electron said put in a c6 5th and 6th(for preferred gas mileage hehe)
Also, the lingenfelter had 2.73 ratio in rear end. Can you mate the 2 c6 5th and a 2.73 gear to faster or are the 2 mutually exclusive and have nothing to do with each other?
Could someone just break down the rear gears and why they would be changed? I intend of having a comfortable vette, is 2.73 or 3.10 a matter when it comes to drivability. I ask because a friend of mine has hard freaking shocks that make my head hurt when riding around town. I know the point is to keep wheel hop down/power to the ground, but its painful, and I expect a vette to be better than that. So can changing the rear gears affect the ride that bad also?
...on second thought maybe I'll read a couple of books or something, that's probably covered in about a couple hundred pages and I'm looking for cliff notes
I only ask cuz I trust the ppl weighing in on the subject.p.s. someone should specialize in Z06electron's suggested tranny rebuild and make the c5's around the country better than the boxy they call a c6 IMHO
I'll be watching replies for sho'
