Self-Threading Shift Knob Help?
Old Sep 28, 2007 | 02:59 PM
NJAnthony's Avatar
NJAnthony
Default Self-Threading Shift **** Help?
This is the most n00bish and silly question I have ever asked... but I am going to ask it anyways. I bought a C6 shift **** for my C5 with B&M short throw shifter from a company with some silly instructions.
You can view the instructions here: http://www.gscreationsllc.com/C6ShiftKnob.pdf
So, the instructions basically say "2) Now place your new C6 **** onto the shifter press down and turn clockwise until tight and in the correct location for you. Do not over tighten.". The guy who sold it to me said it is "self-threading".
My question is, do you slide it down the notch in the shifter pole to the bottom, then push down and start turning, or do you start at the top and spin down? There is a little bar inside of the **** that makes it go down the shifter to a lower part of the pole. I think you would start at the bottom and just do a few turns.... however I feel like if I turn to hard I am going to brake the bar that slides down the notch... is that what is threaded?
Anyone installed a self-threading shift **** before? So easy yet so confusing, and I don't want to break the thing...
Thanks!
Anthony
Old Sep 29, 2007 | 01:57 AM
gator492001's Avatar
gator492001
Anthony, I bought the same **** and when I got it I thought the same thing you did, because if you look down it you really can't see any threads. So I just sliped it on and started turning and sure enfough it threaded its self on, and I turned it pretty hard at the end to get it the position I wanted , once on it won't move. I bought mine from the same dealer.
Old Sep 29, 2007 | 08:00 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep
Old Sep 29, 2007 | 08:59 AM
gomerboat's Avatar
gomerboat
I thought it was odd too, but you just put it on, push down and start turning. To me it feels like it doesn't completely thread all the way, but you can get it tight and it won't move.
Old Oct 2, 2007 | 02:48 PM
NJAnthony's Avatar
NJAnthony
Thanks for the info guys, I just wanted to make sure I didn't break it. I will slip it down the shaft tonight and start turning!
Thanks!
To Self-Threading Shift Knob Help?
