Overheating Problem
Old Sep 29, 2007 | 09:21 PM
WetteVette's Avatar
WetteVette
Old Sep 29, 2007 | 09:28 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
230 is normal in heavy traffic...240 is a def problem...Im sure someone will chime in but I wouldnt run it again at 240 or above
Old Sep 29, 2007 | 09:59 PM
lil vette's Avatar
lil vette
raise car, look under towards top of radiator.
Leaves & dried mud collects up there & blocks about 30 percent of radiator
Old Sep 29, 2007 | 10:14 PM
Whiteonrice's Avatar
Whiteonrice
Might of picked up some trash bags or other debris along the way to Laughlin. Also it is the middle of the desert so cars do run a little hotter when it's like 115 or so. Wait til it cools off maybe around 2 a.m. and see if it still heats up. I have a Pro Charger on mine and when it warms up around here (So Cal ) I have to watch the coolant temps pretty close. Just my .02.
Rick
Old Sep 29, 2007 | 10:27 PM
WetteVette's Avatar
WetteVette
Thanks for the replies so far guys. Something definitely has changed for his temp to suddenly jump 20 degrees.
He's accustomed to driving in hot weather. Here in CA in the central San Jouquin Valley, it gets well over 100 degrees many days during the summer.
Old Sep 29, 2007 | 11:13 PM
If that area is not free of debris, coolant temps will rise significantly.
Old Sep 29, 2007 | 11:16 PM
sneakelman's Avatar
sneakelman
Coolant level: OK
Fans: ON
Thermo open: Check
Sounds like there is definately something restrictring airflow on the radiator, or he's blown a gasket. Any coolant on the dipstick? I'd look toward the radiator being blocked with junk first. Good luck!
Old Sep 29, 2007 | 11:45 PM
WetteVette's Avatar
WetteVette
No coolant in the oil, and the radiator looks fairly clean (no blockage). He said tomorrow he'll inspect/clean it out real well and see if that helps.
Old Sep 29, 2007 | 11:52 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I blow mine out atleast every oil change as it is on the lift and I get lots of crap in mine. If this is not the issue, and his coolant is ok, time for a flush or a DeWitts like I run
Old Sep 30, 2007 | 09:11 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
FWIW Home Depot sells a dryer lint brush....long and thin..allows you to run the brush down both sides of the radiator in addition to blowing it out..I have also used the foaming AC cleaner with good results.
I installed a Dewitts recently as well since my Maggie was causing hi temps with the AC on....it definetly helps but I think I may have to do more when I get the AC back up and running 100%. I have considered some type of additional underhood fan.
Old Sep 30, 2007 | 01:26 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Tell him to check the water and make sure he didnt pick up any trash along the way! !
Old Sep 30, 2007 | 04:39 PM
moserbe's Avatar
moserbe
If the fan is coming on, I would check for crap that is restricting the radiator air flow.
To Overheating Problem
