Wet floor passengers side
Old Sep 29, 2007 | 10:11 PM
78Shadz75's Avatar
78Shadz75
Default Wet floor passengers side
I have a 2000 vert.........I noticed I have a wet carpet on the passengers side, only. The dampness appears to be under the rear portion of the floor mat the most. Could it be connected to the A/C? Do I have a computer in this area that I should be getting concerned about? Any info would be greatly appreciated. Tks
Old Sep 29, 2007 | 10:50 PM
CheckeredFlag's Avatar
CheckeredFlag
two guesses:
I would guess its either leaking A/C condensation onto the carpet because of a problem with the drain hose
or
problem with the heater core
keep us posted on what you find out
Old Sep 30, 2007 | 07:40 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
A/C, heater core, or depending on the passengers age. If your passenger was under 2 or over 90 and without diapers the results will be the same...
Check your utters for debris...
Old Sep 30, 2007 | 09:28 AM
Phanni's Avatar
Phanni
A/C evaporator drain plug is probably clogged. Put her on a lift and clean it out. It is located under the battery box on passenger side. If you don't have a puddle of water under the car after running the A/C for 5 minutes or so, that is the problem.
Old Oct 2, 2007 | 08:50 PM
78Shadz75's Avatar
78Shadz75
Default wet floor Passengers side
Thanks to all respondents..........My first test will be to run for five minutes and see if see have water...................I will keep .....everyone informed. Thanks
Old Oct 2, 2007 | 09:00 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
I had the same thing happen to me during a run to NYC. My BCM got wet and was fried.
Thanks to C5 Naples, he put me on to Bill Curlee's thread about the subject.
http://forums.corvetteforum.com/show....php?t=1246715
If you haven't had occasion to run into Bill here on the Forum, suffice it to say, he's FORGOTTEN more about C5's than most of us know.
My problem was that damn L-shaped hose was clogged
Good luck and be sure to put a towel on top of the BSM until you can figure it out
To Wet floor passengers side
