Rear rattle noise
Old Sep 30, 2007 | 12:48 AM
RogerArrambide's Avatar
RogerArrambide
Default Rear rattle noise
I cant find the noise on my Vette!!!!!
It is just like there are something loose, but something to thin, you know?, I get to check muffler system and saw that there was a little weld leak all around the pipe and tought that might be the noise because the noise is when you are on R or D or any position but dont on P or N, you hear this sound just like the Cat or the mufller box were loose on the inside, but my car has only 7,700kms, is about 5,000miles, so I really dont think that might be but I dont know how to be sure....
Old Sep 30, 2007 | 01:09 AM
Foosevette's Avatar
Foosevette
Do u hear when in park or when youre driving?
Old Sep 30, 2007 | 01:17 AM
RogerArrambide
In park or Neutral didnt make the noise...
It is when put D, when the rpm be goes down, and you can hear the noise that increase when rpms goes up but just between 500 and 800 rpms, then the noise disapear and back when the rpms are again between this..
Old Sep 30, 2007 | 01:30 AM
Foosevette's Avatar
Foosevette
I know this sounds crazy, but about 4 months ago my car was doing that. Especially when in R. There was some rattle noise coming from under the hood. I had someone to shift the gears while I listen and if I can remember correctly the noise was coming from one of the belts.
As of today the noises is gone. What did I do? Not a damn thing. Lots of rattles have come and gone without me doing anything.
You can wait and see what happens or go to the stealership
Old Sep 30, 2007 | 08:18 PM
RogerArrambide
I hear that noise since 3 months ago, or maybe 600miles ago...
A couple a days ago, when I take the car to a muffler specialist, we saw that was a little leak in a welded union... he weld again too perfect..
I remember that the noise was when start to take off the car from garage, you know?, when start the car and put on R while that, and then, when I put on D, before press gas and start to run, listen that.............
Now, that doesnt happen, dont listen the noise in that situation, so now, I can hear it when Im reducing speed to stop and when is near to total stop, hear the same f...ing noise!!........
I want to think that, the weld work have something that involve the noise, you know?, If with that work, the noise "change", there must to be the problem....
I think that might be one cat or muffler box but the car is just like new!!!
To Rear rattle noise
