From: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Having trouble putting belts back on, tips?
I have almost installed a Katech Belt Tensioner and am having issues putting the belt back on. I have the tensioner and the lowest position and can not get the belt on this thing...
1. Skip the water pump.
2. If you drive fast enough, the air flow should keep the engine cool.
3. If I made a mistake here, I am not responsible for blown engine.
(I don't have an answer for you, but someone should.)
Katech Inc. has been involved with the C5-R race program since 1997. One of the first things that was noticed was there seemed to be a bad spot in the rpm range where the serpentine accessory belt would want to jump off of the pulley. This is the origin of our solid adjustable belt tensioner. After installing this tensioner on the race engine, the belt problem disappeared. Even though this problem was found on the race engines, it is also the same case with the standard LSx engines.
These belt tensioners are a must for anyone doing any sort of performance driving with a Gen 3 / 4 powered car or truck. Without it, the belt can be thrown by the stock tensioner. This is not something you want to happen when you are going down the strip or racing around the road course.
*Not recommend for use on supercharged engines unless the supercharger has a dedicated drive.
