ECP Rocker Savers
Old Sep 30, 2007 | 03:32 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Default ECP Rocker Savers
Save Your Rockers For Only $62.00 Shipped
AS SEEN AND TESTED ON CORVETTEFORUM.COM
THE ULTIMATE IN PROTECTION FOR YOUR 97-07 C5/C6 CORVETTE
Steep driveways and speed bumps can be hazardous, not to mention costly to the rockers on your Corvette.If your Corvette is lowered the constant worry of wrecking your expensive rockers is enough to drive you mad. Here at last is a well though out product designed and tested by a Corvette owner. My "ROCKER SAVERS" are made from an ULTRA HIGH MOLECULAR WEIGHT material that is"
EXTREMELY RESISTANT TO ABRASTION...HAS A VERY LOW COEFFICIENT OF FRICTION
SELF LUBRICATING / NON -TOXIC / EXTREMELY LIGHT [less than 1lbs for both peices]
IMPACT / VIBRATION / UV / AND CORROSION RESISTANT
EVEN IN CRYOGENIC CONDITIONS .
Unlike powder coated aluminum that will flake at the first contact it has with a speed bump the colour of my product will always be there.Unlike aluminum that does not stand up well to asphalt and concrete, this material will not wear. Easy to install ,about an hour. Includes all stainless steel hardware & step by step installation instructions. Best of all you can still use your jacking pucks.The "ROCKER SAVERS' give you a 1/2" buffer zone between them and your expensive rockers. PRICED PER PAIR @ $62.00 shipped anywhere in N.America.
www.engineeredcorvetteproducts.ca
Fits both C5 or C6 including Z06 .
WILL FIT VETTE'S WITH ACI ROCKERS
Instructions for the ROCKER SAVERS :
ROCKER SAVERS
INSTALLATION INSTRUCTIONS; Tools needed;
13mm socket
5mm Allen key
5/32” drill bit
Phillips bit screw driver or bit
Hammer & punch
1. Locate the factory bolt just behind the rear shipping slot.
2. This bolt holds the rear aluminum shield. Remove this bolt.
3. Take the rail marked “DRIVER”. The largest of the four holes is your rear location hole.
4. Place the rail up to the hole where you removed the 13mm hex head bolt from and insert the supplied new 5mm Allen head bolt. We recommend LOCTITE on all the bolts and screws
5. Tighten until its snug.
6. Line up the rest of the rail, making sure you are not up against the rocker its self.
7. Once you are satisfied with your placement, remove the tape cover from the two way tape at the front edge, and press firmly into place.
8. Using a hammer and punch mark the 3 remaining holes and drill with a 5/32”drill bit.
9. Insert the 3 remaining SS screws and tighten starting from the SS 5mm Allen head through to the last SS Philips head screw.
10. Repeat same procedure on the passenger side.
ROCKER SAVERS BY ENGINEERED CORVETTE PRODUCTS
Thanks for all your support .
Manny Dasilva
Engineered Corvette Products
Old Sep 30, 2007 | 04:21 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I installed a set of these this week when I had the front spoiler and side skirts added to my car.
Old Sep 30, 2007 | 07:25 PM
pdd000's Avatar
pdd000
Old Oct 1, 2007 | 06:46 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
In stock and shipping daily
Old Oct 2, 2007 | 12:05 AM
yaknow's Avatar
yaknow
Got both the Rocker Savers and Frame savers from Manny a couple weeks ago, couldn't be more satisfied with both. to Manny for a great set of products.
Old Oct 2, 2007 | 12:19 AM
JETZ's Avatar
JETZ
Lookin' good Ray!
Old Oct 2, 2007 | 10:20 AM
FFIN90's Avatar
FFIN90
Thanks Frank, very pleased with the look. Just talked to the shop who installed them for me to get the final costs,
Like the saying goes " you get what you pay for " and they did a fantastic job.
Old Oct 3, 2007 | 06:11 AM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
l current orders shipped today
Old Oct 3, 2007 | 10:19 PM
SS~7's Avatar
SS~7
If you are lowered like me ...you need these! Awesome product ...I use em almost every day! ...
Old Apr 10, 2008 | 11:17 AM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
THE ORIGINAL UHMW ROCKER PANEL PROTECTORS
http://www.engineeredcorvetteproduct...kerSavers.aspx
ROCKER SAVERS
13mm socket
5mm Allen key
5/32” drill bit
Hammer & punch
Manny Dasilva
Old Apr 13, 2008 | 12:47 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
ttt
Old Apr 16, 2008 | 03:27 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
All current orders shipped today
Old May 14, 2008 | 01:32 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
ROCKER SAVERS
13mm socket
5mm Allen key
5/32” drill bit
Hammer & punch
[url][/urlhttp://www.engineeredcorvetteproducts.ca/RockerSavers.aspx]
Manny Dasilva
New batch ready to go
To ECP Rocker Savers
