I will be installing a set of Seat Hoops from West Coast Corvettes. Any tips on cutting the carpet? I have also seen some trim rings or covering around the bar holes. Any suggestions on what to use?
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Give this some very careful planning. I basically ruined my carpet trying to cut it freehand. Haven't found a good solution yet. Good news is the carpet piece isn't too hard to replace (once I find the solution).
I recall that a CF member found those trim pieces at plumbing supply. Try a search. I never seem to have much luck w/CF search; might be a good subject for its own thread.
Having not done it ...but it seems that if you know the diameter of the tubes and their distance apart...then making a template would be very easy....making your cuts from the back side of the compartment..up then lay the templates down..cut the circles out..done
do they make these for FRC's and z's?
Reason: Idunno
I cut my own but i'm not thrilled with the outcome, I would suggest that you just go to a local upholstery shop and let them fit the carpet, one forum member said that is what he did and it cost him 45.00, probably money well spent, that is what i will do with my new carpet
