Need help with diagnostic code P0442
Old Oct 1, 2007 | 11:11 AM
red02c5's Avatar
red02c5
Cruising
Default Need help with diagnostic code P0442
My check engine light came on over the weekend. I ran the codes and came up with one current code: 10-PCM P0442 C
The closest I could find was P0441 EVAP System No Flow During Purge
What does this code mean in english?
Thanks for your help.
Old Oct 1, 2007 | 11:54 AM
skirossi's Avatar
skirossi
4th Gear
P0442 is for a small leak detected in the Evaporative emissions system within the car. This could be caused by a slightly loose gas cap, I'd check there first. Did you fill it up sometime before the light came on?
