Strange shifting first to third
Old Oct 1, 2007 | 07:34 PM
jaybar's Avatar
jaybar
Default Strange shifting first to third
Ok I am new having just picked up my FRC. I know there is that 1 to 3 shift tghing, I did experience that a few times.
But the real problem is that several times when I think I am in first gear and go to start up I find I am in third gear. I make an effort to get it into first and many times it is in third. Is this something caused by that 1 to 3 shift thing.
And, how do I disconnect the 1 to 3 thing?
Old Oct 1, 2007 | 07:40 PM
steve8's Avatar
steve8
If you mean the cags, you need a cags disconnect. About $15 and money well spent. Once it's in the air, a 5 second job.
And it's 1 to 4.
It's not going to magically change gears by itself overnight from 3rd to 1st. Operator error.
Old Oct 1, 2007 | 07:41 PM
MY1STPEWTER's Avatar
MY1STPEWTER
It's actually 1 to 4th that you have to shift if you don't go fast enough in 1st gear. To get what you need click on the link below.
http://forums.corvetteforum.com/show...highlight=cags
Old Oct 1, 2007 | 07:42 PM
Ta-taaa's Avatar
Ta-taaa
And it's 1 to 4.
Quick and easy first mod!! Welcome to the Fourm and congrads on the new ride!
Old Oct 1, 2007 | 07:52 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
"Rangers" tip about using the heal of your hand (away) and your palm/fingers NO thumb (toward) has made shifting with the stock **** much more accurate! Makes sense when you consider the ****'s shape...
Old Oct 1, 2007 | 07:56 PM
LoneStarFRC's Avatar
LoneStarFRC
Shifting 101
Old Oct 1, 2007 | 09:28 PM
jaybar's Avatar
jaybar
Ok,
I did some surfing and read the instructions on how to install the cags eliminator. Two questions, One if you just unplug the connector will it accomplish the same thing. I know it will throw a code. And secondly if I install an aftermarket shifter is it a moot point?
And speaking of shifters I see a lot of reference to Hurst shifters. Is there any other manufacturers of aftermarket shifter I should look at.
I never thought Hurst was that great. I had a MGW shifter on my T56 in a Cobra and it was great. But I can't find any reference of a MGW for a Corvette.
Jay B
Old Oct 1, 2007 | 09:56 PM
Mongolink's Avatar
Mongolink
http://www.ultrarev.com/search.php?mode=search&page=1
check these guys out there are three or four aftermarket shifters here!
Old Oct 1, 2007 | 10:11 PM
ptindall's Avatar
ptindall
Search the forum for a thread about the C6 shifter. The C6 shifter is a direct bolt in, looks better, feels better, slightly shorter throws, and is not expensive. I had a problem with not getting all the way into first and it grinding and kicking out when I first got the car. I have never done it agian after installing the C6 shifter.
Old Oct 1, 2007 | 10:58 PM
LoneStarFRC
Ok,
Jay B
The shifter, stock or aftermarket, has no effect on the CAGS system whatsoever.
Old Oct 13, 2007 | 08:47 PM
jaybar's Avatar
jaybar
Ok, got my CAG's eliminator installed. Things are good. Except I am finding it difficult at times to get it into first gear. I end up starting in third. This has been an ongoing problem its not associated with the new installation of the eliminator.
Is there some adjustment that can be made or would a new shifter help. I have seen references on this forum saying that a zo6 shifter is an improvement. Any suggestions?
Old Oct 13, 2007 | 08:48 PM
02MillenniumVette's Avatar
02MillenniumVette
And it's 1 to 4.
To Strange shifting first to third
