tires problem !!!!
Old Oct 2, 2007 | 01:49 AM
corvette-zo6's Avatar
corvette-zo6
3rd Gear
Default tires problem !!!!
i have zo6 2003 with APS TWIN TURBO , and i have CCW 19" wheels i want good tires to this size ((NO BURN OUT)) ????
Old Oct 2, 2007 | 07:09 AM
RSchleder's Avatar
RSchleder
Default 18/19 CCW's here
I wrapped my CCW's with Michelin non run flats. They are 35x285 front and 30x315 rear. The only issue I have is the Michelin 30's have a rib that sticks out on the side wall and the rib makes the tire appear to stick out of the wheel well more than perhaps the Goodyear non run flats. Just something to consider. Good luck, Ron
Old Oct 2, 2007 | 07:31 AM
VET IT B's Avatar
VET IT B
Any close up pics of the rears? Mark
Old Oct 2, 2007 | 07:42 AM
steveblonde's Avatar
steveblonde
here you can see them
Old Oct 2, 2007 | 03:28 PM
corvette-zo6
3rd Gear
what about the BF GoodRich g-Force KDW 295/35/19 ??? do you think is good ????
Old Oct 2, 2007 | 05:15 PM
KidCid's Avatar
KidCid
CI 7-8 Veteran
I have CCW T10's that I put the Michelin's on as well. These are 305's and only stick out a little bit. BTW, mine are 11.5" in the rear. Check my sig pic.
Old Oct 2, 2007 | 05:37 PM
Vega$Vette's Avatar
Vega$Vette
I have PZeros on my Coupe. My son had the BFGs on his FRC. I felt that the BFGs gripped better then my PZeros.
So yes I believe they are good.
To tires problem !!!!
