Winter Storage
Old Oct 3, 2007 | 08:57 AM
rskeller's Avatar
rskeller
Default Winter Storage
My First Winter: So I will be parking my Vette here soon (in a garage that is insulated but not heated) is there anything special I need to do. It does get pretty cold up here -30 C to minus 40C . I will be starting it every couple of weeks, do I need to do it more. ( Corvette Virgin) How about the battery does it need to be taken out?
Old Oct 3, 2007 | 09:01 AM
KGVette's Avatar
KGVette
yea, sucks to think that time is coming very soon. be sure and put a fuel stabilizer in. I wouldn't think you need to pull the battery especially if you are starting it up every couple of weeks. we'll see what others think. this will be my first winter with mine as well...good luck
Old Oct 3, 2007 | 09:06 AM
steve8's Avatar
steve8
I try to drive mine once/month on one of those perfect days.
Just starting it in the driveway is not advised if you can't drive it. You are better off to leave it alone.
Old Oct 3, 2007 | 09:14 AM
Bugaboo's Avatar
Bugaboo
I play it safe and use a battery tender......If you can't drive it for 20 minutes or so don't bother.......
Old Oct 3, 2007 | 09:28 AM
WvCorvette's Avatar
WvCorvette
Battery tender is the only way to go...
Old Oct 3, 2007 | 09:38 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Haven't used a tender...yet..its one of those things I keep wanting to get! First year I covered car but now I just add fuel stab. and cover it only if garage door will be open so I can use the snow blower. I look forward to those clear sunny DRY winter days to take it out and maybe put some fresh fuel in and get it hot. I usually have the oil changed at the start of winter so it will sit with clean mobil 1 in the engine.
Old Oct 3, 2007 | 09:44 AM
R Devil's Avatar
R Devil
I've stored mine here in Iowa for the last 5 winters. I agree with what's been stated above. Battery tender and fuel stabilizer. Depending on the garage, you may want to cover it. Don't start it unless your going to drive it.
It's tuff to see it setting there all winter but it will be ready to go in the spring.
Old Oct 3, 2007 | 01:07 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Hey Rob...here is another recent thread with some good advice.
Sucks just getting these things and having to put them away for the winter hey?
http://forums.corvetteforum.com/show....php?t=1828059
Old Oct 3, 2007 | 01:10 PM
V-man's Avatar
V-man
St. Jude Donor '08
Living in the Boston area winters can also get cold and windy so I've stored mine all winter and would highly recommend a battery tender. Clean it, wax it, cover it and start it and drive it in the spring!
Old Oct 3, 2007 | 01:17 PM
redstreak98's Avatar
redstreak98
What is a battery tender and where can i get one
Old Oct 3, 2007 | 01:49 PM
Carol & Lee's Avatar
Carol & Lee
Default Winter O NO
Do all of the above and I also spray the engine with a good engine cleaner and then hose it down with the hose without a noozle, no pressure. I spray the engine compartment with WD 40, clean the carpets, a good wax job, open the windows a little and use a car cover even in the garage. one last thing is I us 4 mouse traps with peanut butter next to each wheel and aluminum foil over the tail pipes and get a battery tender at any auto parts store or catalog outfit. Even sears has them, get an automatic one that shuts off when the battery is fully charged and dont forget the fuel stabilizer..then wait for spring!
Old Oct 3, 2007 | 01:54 PM
Cart99's Avatar
Cart99
I have had equally good luck simply disconnecting the battery for the winter -- in my case mandatory since I don't have ac power available to me where I store it. Just reconnect the battery in the spring and start it.
I have been storing the C5 and other vehicles for several (30+)years this way with no adverse effects. Follow all of the other advice regarding fuel stabilizer, fresh fluids, etc., but a battery tender (while a good idea) is not mandatory.
Get a battery tender and use it to keep the battery charged. Fill the gas tank and put in some Sta-Bil to keep the gas fresh. I put carpet squares under each tire and put a few extra pounds of air in each one. I also change the oil before putting it in storage. Finally, I make sure the car is clean and then use a car cover to keep the dust off.
Old Oct 3, 2007 | 02:11 PM
cletus's Avatar
cletus
Don't forget about the mouse protection. I put out mouse bait and a couple of chlorine tabs on the floor because I got lots of mouse nests when I didn't.
Old Oct 3, 2007 | 03:11 PM
jangelo's Avatar
jangelo
Old Oct 3, 2007 | 03:39 PM
rws.1's Avatar
rws.1
here is a good link for you
http://www.corvetteactioncenter.com/...e/storage.html
Apart from that, in order of priority
1. make sure the cooling system anti-freeze and the windshield washer reservoir and lines are freeze protected to 40 below....
2. but Stabil in the gas tank
3. definitely use a battery float charger ( 21st Century trickle charer that automatically adjusts output to match battery drain during storage)
4. DO NOT START the car over the winter. Once you put it to bed do not waken it until it is time to put it backon the road. Starting for short periods results in water vapor withing the engine and exhaust. that means RUST as well with your ambient temprerature, that vapor will condense and freeze.. potentially causing additional problems. Finally, at those temperatures even with 5W30 motor oil, it takes a while for the oil to get to distant engine parts resulting in dry starts and accelerating wear....
Old Oct 3, 2007 | 05:08 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Dont forget about the tires, I inflate mine to 40 psi and park it on pieces of carpet. I don't use a battery tender, i just disconnect the battery. Fuel stabilizer is a definite must! I also put a sheet of visqueen under my car as to keep any moisture from coming up.
To Winter Storage
Old Oct 3, 2007 | 06:47 PM
01000001's Avatar
01000001
I was gonna say, what about tire rotation? Is just parking it on carpet enough?
I live in Texas so I don't need to store mine, but I'm still curious.
Old Oct 3, 2007 | 07:05 PM
MagneticRed1977's Avatar
MagneticRed1977
Add to the above with drive the car for at least 1/2 hr before storing. This gets rid of moisture in the exhaust and oil.
Old Oct 3, 2007 | 07:11 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've been storing mine for years and all I do is disconnect the negative battery terminal. It fires up the first time, every time.
