Wheel Dollies
Old Oct 3, 2007 | 10:30 AM
weinerschizel's Avatar
weinerschizel
Default Wheel Dollies
I would like to pickup some wheel dollies. The ones that sit under each tire so you can roll your car to any place in your garage you like. Does anybody know of a good set to purchase for use on our vettes? I've got the C5 Z06 Wheels.
Thanks.
Old Oct 3, 2007 | 11:16 AM
Richard Nogen's Avatar
Richard Nogen
Sorry Just Lurking.
Old Oct 3, 2007 | 11:22 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Sorry, I guess I thought they were pretty much all the same...??? Nothing special needed, just a nice heavy duty set that will roll nicely!! I have a set in my storage unit, sorry no pics. As long as you get a majority of the tire on it, you should be good to go!! Mine are 10 inches wide I'm guessing? Maybe 12?
Good luck!!
Old Oct 3, 2007 | 11:28 AM
c4cruiser's Avatar
c4cruiser
I just got a flyer in the mail from Harbor Freight and they have a pair of dollies for $29.99 Their number is 32052. The HF website doesn't show them on sale so you probably have to get the flyer as there is a coupon needed to get the sale price.
These dollies have a 1000 lb capacity each with cast iron wheels. Should work for storage or just moving the car around a garage. They are 15 3/4" wide at the outside edge so measure the rear tires to make sure they would fit. Fronts will be no problem.
Old Oct 3, 2007 | 02:17 PM
Harbor Freight, Ecklers, Goriot Garage, etc have them.
Old Oct 3, 2007 | 02:41 PM
Archdog75's Avatar
Archdog75
We use these and they are good qaulity and the wheels on the dollies move easy. Moving the car around in the garage sideways is easy in the back, but the front is much heavier (the heavy engine . Usually, it takes about 2 people to move our car around in the garage.
I found that ecklers was the cheapest, but shipping was kinda expensive because they weigh a ton.
From Ecklers web site:
1953-04 Auto Dolly 12" Car Skates
Makes Moving Car In Tight Spaces Easy
Extra Heavy Duty Construction
8-3/4" Between Caster Studs
Phenolic Plastic Casters Won’t Mar Floor
Move any car around your garage by yourself. The scooped design of Car Skates lets you move your car in any direction, even sideways, with ease, to get in and out of tight spaces. Made of heavy gauge ¼" steel plate, 16" long x 12" wide, with durable red painted finish. The Skates have tough ball bearing casters on 1-3/4" wide, high density, phenolic plastic rollers. Each skate will hold up to 1500 pounds. A set of four holds up to 6000 pounds.
Item# 46109
In Stock
$139.99 set
http://www.ecklers.com/product.asp?p...9&dept_id=1095
Good Luck,
Justin
Old Oct 3, 2007 | 05:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Harbor Freight
Old Oct 3, 2007 | 07:01 PM
hotwheels57's Avatar
hotwheels57
These are $239 at CALIFORNIA CAR COVER COMPANY...
reat for working project vehicles, parking and storing vehicles in tight spaces. Quick and easy to use, simply slide under the tire and lift in seconds with smooth action hydraulic foot pedal pump. Features 6000lb capacity, and fits most 13" to 18" wheels. Built-in carrying handle included for easy transportation.
One year warranty.
You can find them at other sources as well...
To Wheel Dollies
