Correct ATF?
Old Oct 3, 2007 | 05:41 PM
AuburnShrink's Avatar
AuburnShrink
Default Correct ATF?
I have a 1998 manual vette and I am going to change the tranny fluid next weekend but I have a question first.
I went to several places to find the correct fluid but I wanted to check with the experts here first.
I bought Pennzoil automatic transmission fluid which states "For use in vehicles previously servicable by Dexron III/Mercon brands. I was trying to find a fluid that specified Dexron III only but I cannot. The "mercon" word is what is making me nervous.
Is this a safe fluid to put in my car?
Thanks in advance for not making me feel like an idiot. I am really getting into working on my vette myself. So far, I have change the oil and filter/installed an air-bag cutoff switch/fixed my rocking seat problem, and other minor issues.....All thanks to the folks on the forum!
Old Oct 3, 2007 | 05:50 PM
jirasvet's Avatar
jirasvet
Yes,IMO it is, but your going to get posts telling you to use a synthetic brand. Always remember this term "Meets or exceeds GM Specifications" when searching for a replacement fluid.
Old Oct 3, 2007 | 05:54 PM
Jim2003's Avatar
Jim2003
I had the same question in my mind about a month ago. The dingbat manufactors change the name of products and then our manuals use different words.
I used Royal Purple syncromesh (sp). It has been in 4 weeks, and no problems.
The hardest part of the job is jacking the vette up and putting it on jack stands. The fluid change was extremely easy.
Good Luck!!!!!!
Old Oct 3, 2007 | 05:55 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Dexron is a GM name, MERCON is a Ford name.
You are fine using that Pennzoil....
To Correct ATF?
