Front sway bar
Old Oct 4, 2007 | 09:56 AM
BigSexy181971's Avatar
BigSexy181971
Default Front sway bar
I have read in many places were people take off or disconnect their sway bars which they say significantly helps in transferring weight to the rear wheels, but doesn't this affect emergency cornering if needed? Also I am looking to get my 2.73 (crap) gears swapped out for a steeper set. What should I go with? Mostly stock and an 98' A4 car. I will be driving this daily but really want this thing to move down low.
Old Oct 4, 2007 | 10:14 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If you are driving to the track you should disconnect the front sway bar at the track and reconnect it before leaving.
