Low Oil Level
Old Oct 4, 2007 | 08:28 PM
bhoch's Avatar
bhoch
Default Low Oil Level
Could be stupid question of the day.. My car has this and I have checked the oil about 10 times now and it looks to be at a "normal" level. does not appear low, does not appear over full.
Is there something that needs to be reset on it somewhere or is this something I have to have "reset"?
Maybe I am clueless on how to check oil level? Guess it's time to "turn in my man card!"
Oil level really does look OK..
Thanks,
Old Oct 4, 2007 | 08:32 PM
moserbe's Avatar
moserbe
Pull the dipstick. If the oil level is on the full mark, then you are ok. Not sure what you are talking about in reference to resetting something??????
Old Oct 4, 2007 | 09:01 PM
cam99's Avatar
cam99
Thanks,
That happened to me a couple of time, rebooting the car usually makes it go away, otherwise you may need a new Oil Level sending unit.
Old Oct 5, 2007 | 05:21 AM
bhoch's Avatar
bhoch
Thanks for the info!
I'll give it a couple of days and keep an eye on the level. Seems to be the level is fine.
If driving over the next few days and it stays on, I'll check into the oil sending unit.
Old Oct 5, 2007 | 06:28 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
He means the DIC shows low oil and the dipstick shows full...resetting means clearing codes?
Old Oct 5, 2007 | 07:11 AM
bhoch's Avatar
bhoch
Yello95 - Correct Exactly what I was thinking.. on a Re-read this morning - What I said did not make much sense to be eithier!
Ride in this morning, started car - no Low Oil Level message, did not come on during the 25.7 (s)miles ride in to work. So.. Good to go!
Been on CF for a while now (long before owning and a few months after purchase) and it still amazes me how quickly a post is responded to. I wish I WORKED with folks that knew as much / cared as much about their job as the folks here know/care about their cars! Knowledge of the folks here ROCKS!
Thanks,
Old Oct 5, 2007 | 08:19 AM
rws.1's Avatar
rws.1
check for shorted wires on the low oil sensor...
engine heated melted the loom and the insulation on the wires on mine.....
Old Oct 5, 2007 | 08:32 AM
bhoch's Avatar
bhoch
oooohhhh.. I'll take a look at that this evening! Thanks!
To Low Oil Level
