Noob question
Old Oct 4, 2007 | 10:45 PM
Icewind Dale's Avatar
Icewind Dale
Default Noob question
Why does my engine rattle when i shut my car off? I have an 04 M6. I have the car in Nuetral with the parking brake on when i turn the key off. It makes a clunking sound kinda like this 84 Cadilac i had once did when i would shut it off. Just doesn't seem normal. Thanks for any possible info. I should also mention i turn the key off with the clutch depressed.
Old Oct 4, 2007 | 10:49 PM
CF6873's Avatar
CF6873
My 02 Z does the same thing
Old Oct 4, 2007 | 10:50 PM
napacruzerc5's Avatar
napacruzerc5
Cheap gas?
Old Oct 4, 2007 | 10:55 PM
PashaCorvette's Avatar
PashaCorvette
Same here I guess that`s the way it is......
Old Oct 4, 2007 | 11:09 PM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
Ahhh, the dreaded shut off death rattle.
I'll bet that you are shutting the car off in neutral with the clutch pedal not depressed. If you shut the car off with the clutch depressed you won't hear that rattle. It is a normal noise and not a problem. I believe if you search the operators manual it will tell you to shut the car off with the clutch pedal depressed.
Old Oct 4, 2007 | 11:15 PM
Last C5's Avatar
Last C5
It's not your engine, its your clutch. Step on the clutch pedal as you shut it off and the noise goes away.
Old Oct 4, 2007 | 11:16 PM
ddanis60's Avatar
ddanis60
mine does the same thing bud. dont leave it in nuetral
Old Oct 5, 2007 | 12:17 AM
Icewind Dale
cool thanks for the peace of mind....
I do shut it off with the clutch depressed. But at least i know its only the dreaded death rattle.
Old Oct 5, 2007 | 12:19 AM
utryd2's Avatar
utryd2
Someone beat me too it......
Old Oct 5, 2007 | 12:26 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
... I should also mention i turn the key off with the clutch depressed....
Old Oct 5, 2007 | 12:29 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Old Oct 5, 2007 | 12:47 AM
MrLeadFoot's Avatar
MrLeadFoot
Mine doesn't rattle, regardless of whether the clutch is in or out, or whether I'm in neutral or not.
Old Oct 5, 2007 | 09:50 AM
Zenak's Avatar
Zenak
Terminal Vette Addict
the clutch on those is a bit fershnickity!
Leave it in neutral. CLutch IN still however...
Then turn it off. Count 6, then let the clutch out.
I see some guys shut it off and let out the clutch in the same breath, it makes a cluncky noise when you do that.
Ever put in a decent injector engine cleaner?
Old Oct 5, 2007 | 10:41 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hey
If not just the simple death rattle. As addressed above. It could be post ignition fireing. Run some Chevron fuel system cleaner through the fuel system and stay with 91oct or higher gas. Depending on mileage you may need new plugs in the spring.
Old Oct 5, 2007 | 10:43 AM
JJ 86's Avatar
JJ 86
My 98 mn6 does the same thing.
Old Oct 5, 2007 | 11:29 AM
sliebl's Avatar
sliebl
Why put it in neutral to shut it off? You don't leave it parked in neutral do you?
I just pull in the garage, or parking space in first gear, depress the clutch so you don't stall, and shut it off. Then let the clutch out a moment or two later. No rattle, and the car doesn't roll away after you park it.
Old Oct 6, 2007 | 01:22 AM
Icewind Dale
I will try that!
To Noob question
