Gear Swap
Old Oct 5, 2007 | 02:54 AM
largeitalian's Avatar
largeitalian
Default Gear Swap
Swapping 2.73 to 3.42, can anyone tell me the steps of a gear swap? ive never done one before
Ive heard you only need gears from some, others have said full differential, someone shine some light on the subject please.
Old Oct 5, 2007 | 04:26 AM
Black$heep's Avatar
Black$heep
TTT
Old Oct 5, 2007 | 06:17 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
David, if you have 2.73 gears now, your "pumpkin" (the gear casing) is too small to accommodate the 3.42's. Guy's who have the 3.15 gears from the factory have the larger casing and in that case, all you have to do is swap the gears inside. But 2.73 guys have to get a whole new pumpkin assembly.
PS: I had a shop install mine and all I remember is my whole rear end assembly lying on the floor (you basically have to drop the entire rear assembly) While you're there, you might want to give some consideration to a higher stall converter
Old Oct 5, 2007 | 06:41 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
as stated you will need a new carrier. You can order a Z06 carrier with 3.42 gears in it from GM. Installation on the floor is a PITA, but can be done.
You will also need to change your shift points.
As a reference we charge $1695 for the parts, install and the shift point correction.
Old Oct 5, 2007 | 09:07 AM
Patches's Avatar
Patches
I did one at home not long ago.
http://forums.corvetteforum.com/show....php?t=1753571
Old Oct 5, 2007 | 09:25 AM
94legaleagle's Avatar
94legaleagle
Buy the ENTIRE pumpkin w/ the gears you want in it, then swap pumpkins - CajunDude has a GREAT rear end swap write-up on his site and here's the link: http://www.cajundude.com/differential.htm
As I understand it, only a FEW shops in the US are able to successfully swap the gears only and NOT create a whining rear end - swapping gears in the C5 pumpkin is NOT at all like swapping gears in the older rearends.
Old Oct 5, 2007 | 09:39 AM
Patches's Avatar
Patches
Also, DTE can install any gearset you want in your 2.73 case. They developed the rebuild procedure to do so.
Old Oct 5, 2007 | 11:02 AM
largeitalian
ok thanks for all the replies! Can someone expand more on a TC? Is it just used for the track? I never go to the track, so will I need one?
Old Oct 5, 2007 | 11:14 AM
Mike Mercury's Avatar
Mike Mercury
you don't need a different TC; it is optional.
Most do it though because the gear swap has the transaxle torn apart to the point where swapping to a higher stall TC adds just a few minutes of work to the carrier swap project.
Here's a link to my rear gear swap page (with links to others as well):
http://mikemercury.home.att.net/342.htm
and an inexpensive converter upgrade if interested:
http://forums.corvetteforum.com/show....php?t=1715694
Old Oct 5, 2007 | 02:17 PM
94legaleagle
my advice - do 'em both! mine's a daily driver and I put in 3.73's and a SS3200 stall - wouldn't have it any other way, except maybe I should have gone w/ a SS3600 stall -
Also, Mike Mercury has a good write up also for the T/C swap as I recall - I think the link is in his post above.
To Gear Swap
