How do I add fuel conditioner?
Old Oct 5, 2007 | 03:11 PM
OzzyC4's Avatar
OzzyC4
Default How do I add fuel conditioner?
It is once again the time of year that the ground is turning white at night here in the PNW and the time to put the '02 in storage is almost here.
I always use Sta-Bil or Gum Out fuel stabilizer in my vehicles when storing them for the winter.
What I am wondering my first winter with the C5 is how to add the conditioner to make sure it is in both tanks and circulated throughout the complete fuel delivery system including the injectors?
Thanks!
btw, it sure is nice to see goodwrench put a banner in my post, NOT!
Old Oct 5, 2007 | 03:55 PM
WetteVette's Avatar
WetteVette
Add the fuel conditioner to the gas tank. Drive around a little. That should distribute it throughout the system.
As for the annoying ads, pay the $25, become a supporting member, and they will go away.
Old Oct 5, 2007 | 04:42 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
My method was to add the amount needed to about a 1/2 tankfull, drive the 2 miles to the gas station. Fill up and then drive to garage for the winter sleep.
Mixes it quite well
Old Oct 5, 2007 | 04:46 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Most of my adult life I've been a disciplined Sta-Bil user, But since I found Seafoam I've switched to it. Seafoam not only cleans and is a top lube, but also is a "stabilizer" making it a very good choice for storing lawn equipment, boats, snow blowers and of course the Vette.
Old Oct 5, 2007 | 06:01 PM
WetteVette's Avatar
WetteVette
Thanks for the info, Ed. I've used Sta-bil in the past, and I discovered SeaFoam here on the Forum. I've read the label on the SeaFoam, but had forgotten it could do all that!
Old Oct 5, 2007 | 06:27 PM
Add when the tank is almost empty - that way the fuel preserver will be spread to both tanks. Then just run the car for a little while and it will be sucked through the fuel system.
Old Oct 5, 2007 | 06:33 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Old Oct 25, 2007 | 08:52 AM
OzzyC4's Avatar
OzzyC4
I wish!
The car was 3/4 full and I had no time to run it out before winterizing.
(been working out of town , getting home for just enough time to do laundry, mow the lawn, feed the dog and hit the road again )
I added the stabilizer,then took it out for a 60 mile drive. stopped and topped the tank off and put it in the hibernation mode.
Hopefully the stabilizer made its way thru the complete system.
Old Oct 25, 2007 | 01:40 PM
RICorvetteGuy's Avatar
RICorvetteGuy
From: The smallest and most corrupt state in the nation. Rhode Island
Originally Posted by OzzyC4
I wish!
That should work fine.....
Old Oct 25, 2007 | 02:26 PM
6spdC6's Avatar
6spdC6
I wish!
You will be fine!
To How do I add fuel conditioner?
